Slow brake pedal return
Discussion in 'Tech Info' started by 991500quad, Mar 3, 2014.
  1. 991500quad
    991500quad Junior Member
    Mar 2, 2014
    Ram Year:
    1999
    Engine:
    5.2 318
    I am new to this but need some help. I have a 99 1500 quad cab with a 318 and a manual transmission I have recently been experiencing slow brake pedal return (anywhere from 2-8 seconds). After a little research and $250, I still have the same problem.
    What I have done;
    -I replaced;
    Power booster
    Master cylinder
    Vac. hose from intake to booster
    -I bled the brakes )furthest from the MC to the closest
    -lubed the pivot the brake arm is attached to
    -scratched my head.
    Some reading was telling me the booster was bad so that is why I replaced that. a little more reading and locals said it sounded like a bad MC so I replaced that. What clued me onto this was braking at a stop sign, letting off and seeing my trailer brake controller was on (normally is when brakes are applied). Thinking this was odd, I lifted the brake pedal with my foot to see if the light would go off and it did. I remembered my parents had the same issue on their 99 durango but don't remember what fixed it.
    Never the less, over the last few weeks, I have dealt with the pedal slowly returning but enough is enough, I want it fixed. Camping season is coming, as soon as the snow melts.
    A few people have said to adjust the light switch but that wont speed the pedal return up and others have said a spring but again, something must be wrong for the pedal to act like this.
    I have recently read something about the the rear brake pistons????? is this a sign of worn brake shoes in the rear??
    Like I said this was a sudden issue. One day all was well and the very next the problem started.
    Please help me out folks. I know there is a lot of great info out there and surely someone has experienced this before me. Funny thing is all the Dodge dealerships, Les Schwab and other brake repair shops have all said either they have never seen or heard of this or it is common for the Dodge brake pedal to return slow. They don't understand when I tell them this is just no occurring which is why I was calling.
    I am not afraid of getting a little dirty to replace something if need be, just not excited about dumping more money into something that might not fix the issue.
    Thanks all!!!
  2. dodge dude94
    dodge dude94 Senior Member
    23
    27,424
    6,268
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Never had that issue but I have had pretty much my entire braking system replaced.
    I had a bad MC, went to the shop, and ended up going through 2 more MCs before a new one was purchased and installed. So a reman MC being bad isn't out of the running.
    My truck failed the brake test during inspection one year, so I had a new booster installed, passed inspection and brakes felt better. However, when I got the plenum replaced later that same year, my pedal feel was even more better after that. You should also pull your drums and make sure the linings aren't worn and your wheel cylinders aren't leaking. The rear brakes contribute hugely to pedal feel.
    Hope you get it figured out and welcome to RF.
  3. 991500quad
    Mar 2, 2014
    Ram Year:
    1999
    Engine:
    5.2 318
    I will check the rear brakes this weekend. That is the last part to check that I haven't touched besides when I bled them. Thanks for the info. I'll let you know if it works.
  4. 991500quad
    Mar 2, 2014
    Ram Year:
    1999
    Engine:
    5.2 318
    I checked the rear brakes, they are still in good shape and the wheel cylinders and great with no leaks. Any more ideas?
  5. dodge dude94
    23
    27,424
    6,268
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Were they adjusted properly?
  6. leadrofthepak
    leadrofthepak Senior Member
    42
    357
    101
    Mar 3, 2014
    Shelton, CT
    Ram Year:
    1998
    Engine:
    5.2
    Even though the rear brake cylinders can appear to be leak free and fully functional, once removed you may find that they have no recoil to them at all. Both rear brake cylinders on my truck were like that when I bought it, dry as a bone and looked fine but once I took them out they were sloppy and dead, maybe blocked up or something. Word of caution: use a generous amount of penetrating oil on the line fitting if you are going to replace them. Replacing the lines is less than fun... at least from my perspective. I would also opt to replace the drum hardware as well, while you're in there and all.
  7. 991500quad
    Mar 2, 2014
    Ram Year:
    1999
    Engine:
    5.2 318
    Yes everything was adjusted great. I have read about the nightmares replacing the cylinders. I am going to do a little "tweeting" on the push rod on the booster first. Seems like the easier of the two. If all else fails, I will spend the few bucks on the cylinders. Will keep you all updated as I go.
  8. 991500quad
    Mar 2, 2014
    Ram Year:
    1999
    Engine:
    5.2 318
    Well guys and gals I have put new wheel cylinders in, re bled the brakes and every thing is alittle better by not fixed. If I use full brake the pedal is somewhat normal but not snappy. If I apply very little brake the pedal takes about 3-4 seconds to return about 1" of travel. I am at a loss with no more stuff to replace. I need more ideas and help please!!!
  9. leadrofthepak
    42
    357
    101
    Mar 3, 2014
    Shelton, CT
    Ram Year:
    1998
    Engine:
    5.2
    I have never had to dive into the brake system of my Ram this deep. Do we have a proportioning valve and if so could that be a potential culprit for this problem? Sorry bro, I am trying to think of possible solutions.
  10. Merc225hp
    Merc225hp Senior Member
    5,141
    3,117
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    ^^^ Yes we do have a proportioning valve on these trucks, we also have a piss poor ABS system as well. I would start by replacing all the soft lines and go from there.
Share This Page
