Slow brake pedal return
Discussion in 'Tech Info' started by 991500quad, Mar 3, 2014.
  1. Jamarctatum
    Jamarctatum Junior Member
    Nov 18, 2015
    Ram Year:
    98
    Engine:
    5.9 cummins turbo diesel
    Did you ever figure it out? I'm having the same problem. New Mc, new hydro boost, 2 calipers, new brake lines front, new pads and rotors front, adjusted brake light switch and bled the entire system.
  2. peboiteau
    peboiteau Junior Member
    Dec 2, 2015
    Ram Year:
    1998
    Engine:
    Cummins 5.9l 12 valve
    I'm also interested... have the same problem.
    Question: When you replaced the hydroboost, have you also replaced the spring between the hydroboost and the MC?
  3. KianaReed
    KianaReed Junior Member
    Nov 30, 2016
    Ram Year:
    2001
    Engine:
    5.2
    Wow, no final answer on the problem?
    Unfortunately my GF's truck is going throgh the same problem...
    So her brother who is going to school to be a mechanic and graduated replaced her front disc pads. (01 1/2 ton extended 5.2)
    However she starts having braking problems. I find the reservoir empty, top it off and one of he bleed valve was either cross threaded or just completely coroded to the point that I couldn't loosen the valve.
    So I will buy a new caliper and go from there, because she lives so far away I can't easily work on it especially being the winter in Alaska. Have to find a garage/shop. Anyone in Anchorage, Alaska able to help a guy & girl out? I would provide the tools, just need a shop.
Share This Page
