Slow performance
stang80s
US
I have 99 ram 5.2 with 112k miles on it. I have no check engine light on. I feel like truck has no power, I can't even peel out when I floor it from a stop in rain. When I pull a trailer with a car it has absolutely no power to pass or go up a hill. Also pings when going up slight and large hills when I give it for gas. Any suggestions?
Sent from my VS995 using Tapatalk
S
stang80s
US
Forgot to mention it a 4x4 and automatic.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
have you or anyone else done the Plenum repair yet?
S
stang80s
US
I have not done the plenum repair. I'm going to check compression and do a vacuum test. I'm thinking that is my issue with a clogged cat. I just got the truck like 3 months ago.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
If it is the cat it will likely be bright orange after a drive if it is plugged. We had this happen on our 98 Ram that thing should have started a fire but somehow didn’t.
S
stang80s
US
Would you say about a 30 min drive?
S
stang80s
US
This is my first dodge ram and I can't believe that in rain I can't even spin the tire (non posi)!!!
crazykid1994
I’d be checking plenum. I did the plenum on my 97 and changed the front o2 at the same time along with some new plugs. Depending on how bad it is you may need new cat. I ended up cutting mine out since it was an off-road truck. Made a heck of a difference
dudeman2009
Magnum 360
If its the cat then you won't be able to rev past 3Krpm usually, unbolting a downpipe will quickly fix the issue.
S
stang80s
US
It definitely goes past 3k on the tach
Gr8bawana
6.7 CTD
You didn't mention this before but how tall are your tires and what gearing does your truck have?
Tall tires and tall gears make for a very gutless truck.
S
stang80s
US
245/75-16 3.55 gear
