Snow Plowing w/ lift kit?
Discussion in 'Lifted' started by FireRescue462, Jan 9, 2017.
  1. FireRescue462
    FireRescue462 Junior Member
    20
    Mar 18, 2015
    Rhode Island
    Ram Year:
    2001
    Engine:
    5.9L
    What do I have to do to put a plow on my truck? 2001 Ram 1500, new to the snow business. Want to put a setup on my truck. I believe it's a 5" lift. 35" tires. 4X4. Help!! Want to do it soon!!
    Joe w. likes this.
  2. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Bolt the mounts up and go. Wire it in and everything. You'll just have to run with the plow lower i would think
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,398
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    You'll have to measure the stock brackets to make sure you will have enough travel on the plow, you will want at least 2in of travel below the distance on flat level ground. Otherwise if the maximum travel barely brings the plow into contact with the ground, as soon as there is a dip, the plow won't be able to drop into it until the front tires do.
    If you cant get enough travel, look around for kits that supply plow drop brackets or mounts. There are plenty of lifted trucks with plows, aside from the possible need for drop brackets, everything is the same as on a normal truck. Just make sure you put the electrical solenoid someplace it can get airflow over it.
Share This Page
