So what's the verdict?
infernoredram
South Texas
5.9 Cummins
One of the most asked questions...diesel idling, good, neutral, or bad?
I have looked all over the interwebs and have not found a single straight up answer or any proof of what it does, if anything.
At my university, one of the bigger departments is agriculture, so you see a lot of diesel trucks around campus. Something I'm always seeing, are those guys in their trucks sleeping, or just waiting for a class. Are they hurting the trucks idling like that, or does really have no affect on the diesel?
Nickxxxr
Near Reading, PA
Don't have a real answer for you but my diesel service truck sits and idles at every call i go on for the compressor. About an hour to hour and a half probably six or seven times a day for ten years now. She is still running strong.
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
My work CTD stays on about 90% of the day on different sites.... but then again it's a 2012 with 5K on it so I have no idea if it's harmful or not.. not enough time with it
MADDOG
Not RamForum Staff
My contractor buddy runs 12 - 15 CTD's in his fleet. In the winter they idle all day. His only problem has been with the newer trucks and the DPF clogging up. Other than that, he has a couple of older 5.9's with over 200K on them and they are still going strong. They don't look all that great, though. ;)
infernoredram
infernoredram
South Texas
5.9 Cummins
Lol yeah I've heard it's bad to idle the DPFed trucks, but it's not bad on the 5.9...I've also heard that the fuel coats the cylinders though?
ramhunter9
P-Star Jeep Wrangler
I let mine idle all the time .. even on cold days start ups I set her to hi idle mode
Stangshcky12
Oshkosh, WI
5.9 Cummins
I'm in the Ag dept at my university lol
Idling can cause dpf on the newer trucks but I don't think it does anything to pre -07
A big reason your here bad things is because of emmisions. With how many large trucks are idleing around the world at any given time its quite a bit
ramhunter9
Emissions ... whats that ..LOL
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
infernoredram
infernoredram
South Texas
5.9 Cummins
Great info Michael...that's exactly what I was looking for! Thanks for all the responses....now I just need the money to buy gauges to watch my EGTs..
Mopar1973Man
New Meadows, Idaho
Like my comment about vehicle accidents I use to work for the local fire dept and have to get walking injured people off the highway into a warm pickup when weather was bad. So 6 cylinder high idle and my exhaust brake I could hold 500-600*F worth of EGT's and coolant temps would stay up with the heater rolling full bore. Then all my emgenecy lights too running...
So while your looking at getting the pyrometer you might consider building a high idle kit for your truck too...(On for 98.5 to 02).
Mopar1973Man's Dodge Cummins Articles - High Idle Modification
Here is how it operates...
High Idle Operation - YouTube
infernoredram
infernoredram
South Texas
5.9 Cummins
So right now I'm idling in my truck waiting for class, and I have the high idle on. I got a few more questions...
1.) when do you need to actually use high idle? When you idle for 10min? 30min? 1hr? Etc..
2.). Does it hurt your idling fuel economy? (if there's such thing)
3.). My high idle is set at 1100 RPM, is that correct?
Btw...I live in south TX, so cold temps don't really exist. Its 84 right now
ramhunter9
I only use high idle when the temps are cold . Helps heat the truck up better at first start up . After that I dont ever use it .
Why you would even use High Idle in Texas is beyond me ?
And yes 1100 is fine .
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Well, it got down to freezing one night this winter. Lol. Mighta needed it then!
Stangshcky12
Oshkosh, WI
5.9 Cummins
At 84 youll be fine haha, the autmotatic high idle only functions when the IAT is below 32* or the coolant temp is below 175*
Your truck will be fine idling at normal rpms when its that warm and I doubt your going to be in the truck for more then 2 hours
infernoredram
infernoredram
South Texas
5.9 Cummins
Ooooooh lol. I was told to use it to
Prevent wetstacking(?)..unburnt fuel coating the cylinders and creating problems in the engine. I don't know if that was just cold weather though? Lol
WhiteExpress
Midland, TX
I used to let my '95 idle for hours when it was BF cold outside. Maybe the 12Vs didn't have any issues with it. Truck always ran great, heater was always nice n warm.
Mopar1973Man
New Meadows, Idaho
!2v's doesn't have this issues because the cylinder are slightly higher from the head configureation. Where the 24V tends to run cooler and this problem starts to turn up. Heck yesterday morning I started out at +6*F above and had a high temp of barely 33*F...
