02ramboi
- Mar 30, 2017
- 1,765
- 1,099
- Location
- live oak florida
- 2002
- 4.7 v8
ok excellent. so search for x11 NOT for x12.5?
Correct 11-11.5
I've never seen an x11 or x11.5 tire. I think you're gonna have to use the metric sizes to get what you want.
if what i found is correct then 285X75R17E would be metric. can anyone confirm?I've never seen an x11 or x11.5 tire. I think you're gonna have to use the metric sizes to get what you want.
thank you so much! yes my current tires are 265/70r17s.Yeah, 11.22 wide, 33.84 tall. Here's a great site to get tire specs AND compare sizes at the same time.
https://www.tacomaworld.com/tirecalc?tires=265-70r17-285-75r17
I've already punched in the two sizes for you. You can enter any sizes you want, including the non-metric ones. But you cant mix a sizing like 35/40r17 or something like that. lol.
Also, I wasn't paying attention, but I'll assume you're on stock 265/70r17 right now.
this site is awesome. will i need spacers for this tire?
Excellent. Will a 3inch level make this easier or should i stick with the 2 inch?No you won’t but if you wanted to buy them to get that off set it will look really good 1.5 hubcentric spacer from bora
it shows 2 inch difference but idk how level the ground is. i cant stand the rake..it looks good on my fathers 83 el camino but not on my truck haha. i think im gonna go with 3 inch.AFAIK, 3" level will make you perfectly level or the tiniest bit ass down. 2" level will leave you with some rake. 2.5" level will be perfectly level or the tiniest bit of rake.
Actually, eff all this, go out to your truck on level pavement and measure from the ground to the top of the wheel wells all around. Figure out the difference front-rear, and go with the level that will give you the stance you want.
But to answer your question, I'd say it would be 'easier' with a 3" level to fit bigger tires.
damn thats ******. is that yours?
is this a good one?
https://www.amazon.com/Supreme-Susp...ROG6/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
