Marshalladkins
- Oct 3, 2016
- 11
- 0
- 2013
- Hemi 5.7
have a 2013 ram with the 5.7 hemi just wanting to find out what plugs to run everyone is telling
Ngk iridium
Ngk iridium
Are you sure you have iridium plugs if not you should find out? I believe in 2013 you could also have the older copper plugs that require changing every 30,000 miles or so.
I had a 2013 that was totaled by a red-light running semi-truck, and now have a 2014.
The 2013 was built in the very early part of 2013, so probably a middle of the model year production. It had copper plugs, I checked.
The 2014 is a late 2014, and it has iridium plugs.
E3 plugs are mostly marketing. I've heard of very few to no good results with pretty much any Ram from 2nd Gen (1994-2001), with the ol' Magnum engines, all the way to the 2018s. Haven't heard of any issues with the 2019 Rams, but they haven't been around long enough to need spark plug replacements yet. Personally, as the Hemi is mostly unchanged in the 2019s other than eTorque, I doubt the E3 plugs will work well in them either.
As others said, I'd advise to stick with NGK iridium plugs, or OEM, which are also NGK iridium plugs.
