Spoon bars clunking
Discussion in 'Lowered' started by big john 02, May 26, 2016.
  1. big john 02
    big john 02 Senior Member
    36
    309
    29
    Dec 14, 2014
    Ram Year:
    Engine:
    Ok guys like it says I was wondering if anyone else uppers and lowers are clunking my truck is a 14 RT with the 8 speed, And the sphoon bars are clunking ofer bumps and on downshifts. I have the tool to tighten the spheres but was wondering if anyone was having this issue and did it stop once you tightened the bars up,
  2. bgray
    bgray Senior Member
    32
    460
    192
    Feb 11, 2015
    Canada
    Ram Year:
    Engine:
    %150 thats the issue. Both my 15 rt and 16Sport did it after new bars went it and i put 2000km on them. Drop em down and crank em tight!
  3. razor1
    razor1 Senior Member
    55
    365
    166
    Dec 27, 2015
    St.Petersburg Fl
    Ram Year:
    Engine:
    mine clunk too, been trying to find the reason. Everything was done on a drive on lift and tightened with full weight on the suspension. Sounds like they are moving around, but don't anything loose.
  4. bgray
    bgray Senior Member
    32
    460
    192
    Feb 11, 2015
    Canada
    Ram Year:
    Engine:
    Its the del sphere joint. Has nothing to do with install or loose bolts. The del-sphere join ts have a break in, once they break in they loosen up. You need to drop the arm(1 bolt at a time on the ground or drive on lift) and use the bushing tool to tighten the joint. Clunking is caused by play in the bushing under load(which you wont be able to detect by hand)
  5. bgray
    bgray Senior Member
    32
    460
    192
    Feb 11, 2015
    Canada
    Ram Year:
    Engine:
  6. razor1
    55
    365
    166
    Dec 27, 2015
    St.Petersburg Fl
    Ram Year:
    Engine:
    thx bgray, ordering today
  7. Dubstep Shep
    Dubstep Shep Senior Member
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    The Spohn bars will always have more noise than the stock bars. That's just part of the trade off of having stiffer joints. Delrin transmits a lot more NVH than rubber.
    That said, once the bars break in they do need to be tightened down.
  8. R/T_Fire
    R/T_Fire Senior Member
    36
    3,396
    1,155
    Feb 3, 2015
    Pleasant Grove
    Ram Year:
    Engine:
    Good info.... I need to order me up a adjusting tool.
  9. bgray
    bgray Senior Member
    32
    460
    192
    Feb 11, 2015
    Canada
    Ram Year:
    Engine:
    I spent a solid 3 hours one day, removing parts on and off my truck trying to isolate that clunk. You'll never feel the play when checking the rear end which is the issue.
    It was after i felt defeated, i went to spohns website and the first thing I saw was an advert on there delsphere, Instantly i realized it was likely them. Watched that video and was even more certain lol
    big john 02 likes this.
  10. big john 02
    36
    309
    29
    Dec 14, 2014
    Ram Year:
    Engine:
    I knew that was the issue I could actually turn my bars from side to side, pulled the spoon off and reinstalled the factory bars problem solved, Now I tightened them bad boys up off the truck do you think it will be ok to reinstall the spoon arms?
Share This Page
