Gary's Hemi
The benefit is worth the work.
How much do you drive a day if you dont mind me asking? If they loosen up & clunk as often as some have said I would be taking them off & retightening them every 2 weeks.
Don't forget that once the bushing settles you have to grease it. If you don't then it will start clunking again. I'd suggest greasing them every 5,000 miles or so.
I think the biggest issue is not keeping them greased. I'm going to be grabbing by grease gun every 5,000 or so miles from now on. I also put some zerk fittings in my sway bar bushings to solve that squeaking and it worked like a charm.
After a day at the drag strip I had same clunking Issue. Got home, and the retaining clip had popped off the joint. Pulled them apart to fix the problem, re-adjust and clean out old grease, found I also had 2 cracked bushing cups. Put everything back together, torqued the crap out of them, and re-installed. Clucnking was gone, trans shifting clunk was gone, the truck felt awesome. I also Called Spohn, was told over tightening will cause them to crack which is BS, I installed them as they came from Spohn initially, and they cracked due to wheel hop.
Last weekend went on a 1500mile drive up and down PCH, and the noise & trans clunk has come back.
Went ahead and ordered 16 new bushing cups, and will be doing a complete R&R soon. I'll be leaving them pretty snug, and lining the inside of the frame and axle mounts with rubber liner to reduce the noise.
I wouldn't buy the Spohn arms knowing what I had to learn the hard way.
I'm making over 500RWHP, and launch it pretty hard. These units will be for sale soon, as I am building custom tubular units using FK Heim / Spherical ends. If it makes noise then, oh well, at least I know they will be solid.
It's just good practice to lube the chassi every oil change.
Over tightening can crack them, as can not having them tight enough because they'll impact.
Even solid joints will wear out, especially driving around on the street.
Honestly the stock rubber bushings are about the most maintenance free bushing you can possibly get in a car. Generally the more "racecar" you go, the more maintenance there is to it.
I do, but oil changes for me are every 10,000 miles and I'm probably going to have to lube these more often than that.
good , but do take alot to get them broken in I guess. On my forth round of adjustments today.
How involved is adjusting? Do you have to just remove the side with the del-sphere joint and tighten it?
How long would you say it takes to do all of your adjustments?
I have not installed my suspension components yet so I don't really have an understanding of how long this stuff takes.
The arms should be removed from the truck to adjust. You can do it one end at a time by removing one bolt, and dropping them while leaving them on, but its a PITA to hold them while you tighten them up.
Good luck. Many people don't have any problems. But adjusting all the time, and the 2nd failure made me find an alternative.
SKWURLZ, those look great!
I like my spohns but the adjustment and clunking is annoying, im thinking it may be other susp geometry related which may explain why some have issues and others dont. When i stretched mine to oush the axle back is when alot of the clunk began. But thats a whole other discussion.
For those wondering where to source parts from to make your own look into ballisticfabrication.com
Here is their bad ass joint.... 3.0" Forged Ultra Duty Ballistic Joint
You could also use this one at the frame to help witg vibration but still get the benefit of the adjustable rod end or heim style joint at the other.
Ballistic Forged Poly Bushing 2.63"
There are many 4x4 crawler websites that will send you the parts you need to make your own HD arms.
Sent from my SM-G920V using Tapatalk
