spring/shock combo?
CrumpManJr96
Fresno, CA
5.9 Magnum
this might be a dumb/previously covered question but i havent found any info on it... my truck currently has a spacers/blocks kit on it. im not sure what brand it is but the block in the rear seams to be 2.5", it also has a dual shock set up up front. I want to get rid of the spacers and blocks (starting up front) and replace with new springs/leafpacks... what brands should i go with or stay away from??
BBartow
New Port Richey, Florida
5.9L Magnum
When it comes to coil springs and leaf springs there aren't really any brands to avoid. They're pretty simple so most people just look for whatever is cheapest. You will also need new lower control arms at 3" lift and an adjustable track bar is highly recommended at this point.
CrumpManJr96
CrumpManJr96
Fresno, CA
5.9 Magnum
ok cool. it has aftermarket upper and lowers on it already so im good there.. thanks
Merc225hp
NA
truck
gas
Not all coil springs are the same, there are three main types; Linear, Progressive and Dual rate. You would have to check out each spring and see what's out there that suites your driving style and needs. Places like BDS and Carli offer progressive rate springs, much better riding spring over a linear spring.
Edit: In the pix below the black spring is a BDS Progressive coil spring were the red spring is a Linear rate spring.
CrumpManJr96
CrumpManJr96
Fresno, CA
5.9 Magnum
ya ive been looking around and im really liking the carli 3" multi-rate coils, ive seen nothing but good reviews on all their stufff... thanks
