well, assuming the dimensions fit, like i said in your mod thread, you would need either a new combination valve, or an aftermarket adjustable porpotioning valve. drum brakes take ALOT more hydraulics to operate compared to disc brakes, so you if you don't change out the valve your new disc brakes would lock up when you hit the brakes. i've heard of people being able to get away with not messing with it, but i wouldn't do it. my 02 has rear disc, so in theory you should be able to get a combination valve for my truck, and put it on your truck. I know your brake booster is vaccum powered, while mine is hydraulic (off the power steering pump) but i don't see that changing anything with the brakes...than again i am 90% sure my front calipers are dual piston, and rears are single. so that would also need to be checked into, does the srt10 rears have single or dual piston calipers? does it have the same lug pattern as your truck? if anything, i would guess it would be wider than your stock axle. but would the stock shock mounting locations work? I saw it at my local "we will rip you off but own every junk yard in the area so your kinda screwed anyways" junk yard while i was grabbing something for my truck (freaking rip off but thats another story...) If i were you, i would check your junk yards, i bet there is one in there. But with a little fabrication, i know you can make it fit. i would be surprised if the srt10 has a smaller stance. If memory serves me, 01 was when they started offering rear disc in the 2500/3500. idk when they started it in the 1500 but i bet it was in the third gens. possibly also look into GM axles, the 14 bolt is stronger than a dana 60 any day of the week, and has a better lubrication design, and that was available in rear disc applications in the 2000s, and i believe all Z71s have LSDs. I think the RPO code is G80, so you can double check it there in the glove box for that. base model Z71s did not have a LSD, but uprated models did. I think a 14 bolt would work, but idk, these could just be the ramblings of a guy who just got off a 16 hour shift and found out there is a damn good chance everything he did today might have been pointless....
