steering tight
the codes
Houston, Tx
Magnum 5.2
every now and then the wheel gets somewhat stiff when turning and i was just wondering what could be some causes of this and what things I should look at to correct the problem.
thanka
Tapatalk Addict
HolyRamBatman
Deep in the Heart of Texas
I would look to the power steering pump. I didn't notice this in your upgraded suspension list. It may be starting to go out. Fluid may be low or over used.
Any noise involved? Certain road type when you turn and it acts up?
Steering gear?
man n black
Cummins
Outside temps cold? Could be viscosity change related to cold temps or old/poor fluid.
Cheers,
Ch
Sent using XT912 M
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Try flushing your power steering fluid and see if that helps. You'll need a suction gun and a 1/2 gal of ps fluid.
Could be a bad idler arm or...
Worse case scenario...gearbox dying.
the codes
the codes
Houston, Tx
Magnum 5.2
thanks for all the info gents. very helpful. I will start with the fluid. any of you have a brand to recommend?
Tapatalk Addict
the codes
the codes
Houston, Tx
Magnum 5.2
oh and to answer the when question, it's mostly at city/parking lot speeds on pavement.
Tapatalk Addict
the codes
the codes
Houston, Tx
Magnum 5.2
so to change the fluid, from what I understand the procedure is...
use a suction gun/turkey baster to suck what is in the resovour out
add more fluid-turn truck on-turn wheel a few times-suck fluid out-repeat
comments??
and anyone have a brand of fluid to recommend? I watched a guy on youtube put atf+4 in his power steering res?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I have heard you can use atf+4 but I would think any normal power steering fluid would be good.
the codes
the codes
Houston, Tx
Magnum 5.2
alrighty, what did you think about the process I posted? look right?
J-Ram
Did flushing the PS fluid fix your issue? Mine is doing about the same thing. especially when its cold outside.
