Switch back boards
Leveil22
Have you and the manufacturer come up with a plug n play setup yet?
Also what DRL system do you recommend?
I read somewhere that these LEDs are not as bright as factory is that true and is there an option to make them brighter?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
****! Sorry - been nuts around here lately!
As for PNP......no. The plugs required to do that just aren't available readily......then.....OEM is different than aftermarket, making it more fun. At this time, its soldered in or crimped.
The white - from my experience, plenty bright. Have to remember, stock is amber.....hard to compare amber to white.
DRL, I have a harness ran for mine. I tapped to a fuse that is active when the truck is running (mine is the sunroof fuse) - and it then provides power to the lights. Its overridden when I go to parking lights.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
