Synthetic Oil
Discussion in 'Engine & Performance' started by mcclintock89, Feb 7, 2013.
Oil of Choice
  1. Castrol Syntec/Edge
    111 vote(s)
    8.8%
  2. Royal Purple
    192 vote(s)
    15.3%
  3. AMSOil
    186 vote(s)
    14.8%
  4. Valvoline Synpower
    66 vote(s)
    5.3%
  5. Mobil 1
    471 vote(s)
    37.5%
  6. Other
    230 vote(s)
    18.3%
Sponsored By: Moe's Performance
  1. Grad12
    Grad12 Senior Member
    178
    10
    Aug 17, 2014
    Ram Year:
    Engine:
    v6 3.6
    5w20 rp since it's first change 3 since then. I'll keep posting to the forum when it hits some big mileage or I get a hickup with rp. But I'll be sticking with that for now.
    Burla likes this.
  2. dtru1222
    dtru1222 Senior Member
    218
    25
    Jul 22, 2012
    Ram Year:
    Engine:
    This will probably get burried in the many pages but something that no one ever mention or thinks about is VVT operation.
    It was stated by one of the SRT engineers that a high moly count helps with the VVT operation, and in their SRT blend it has a high moly count. Most brands that I have seen do not. I was running Amsoil XL 5-20 and noticed a much more smoother power delivery when I changed over to the Signature Series which has a higher moly count.
    SyN and Burla like this.
  3. rocket
    rocket Supporting Member
    14,798
    2,344
    Jun 26, 2010
    connecticut
    Ram Year:
    2006 Nightrunner
    Engine:
    HEMI 5.7
    what is this signature series you speak of??
  4. TomR00
    TomR00 Junior Member
    22
    Oct 17, 2013
    Pennsylvania
    Ram Year:
    Engine:
    I just changed my oil on my 2013 Express, 7,012 miles to Mobil 1 Full Synth and M1-113 filter. What a difference in the engine, runs a lot smoother and I can hardly tell when the ECO mode kicks in.:)
    Wondering now if changing the transmission and axles to full synth would also make any difference.
    TomR
  5. hemihustlin
    hemihustlin Senior Member
    1,097
    306
    Jul 23, 2013
    Montreal
    Ram Year:
    2006
    Engine:
    @ rocket: amsoil ss is the top of the line 1 year 25k oil (normal service lol, read the fine print and almost everybody fall in the severe service category which is like 10 or 15 k miles
    The transmission oil is already syn. I would leave it in untill it needs to be changed then you could go with something like redline atf+4, if you had a 6 speed.
    If you have the 8 speed im pretty sure they are "sealed for life" and i wouldnt touch it.
    Gear oil is probably conventional but good quality. Again i would leave it in untill it is due to be changed.
    You could change it right away if you want, but with the little milage you have it seems wasteful. Unless you see obvious signs of contamination when checking the fluid.
  6. rocket
    14,798
    2,344
    Jun 26, 2010
    connecticut
    Ram Year:
    2006 Nightrunner
    Engine:
    HEMI 5.7
    my rear pinion seal started leaking 20k miles after I did the change......take it for what its worth
  7. smiley3303
    smiley3303 Super Moderator Staff Member
    31
    5,689
    1,443
    Apr 18, 2011
    Minot, ND
    Ram Year:
    2009 Ram 1500 Laramie Crew 4WD
    Engine:
    I agree mostly but rear axle is almost certainly synthetic the front could be either. This could have changed but that was the manual read from what I could tell.
    $miley
  8. rocket
    14,798
    2,344
    Jun 26, 2010
    connecticut
    Ram Year:
    2006 Nightrunner
    Engine:
    HEMI 5.7
    I really think it was just it's time......not out of the area of impossible
  9. dtru1222
    218
    25
    Jul 22, 2012
    Ram Year:
    Engine:
    They have the original, XL and SS types of most weights. I went on the "bob is the oil guy" forums and saw some oil analysis sheets that showed that the SS has a higher moly count than the XL so I switched over.
  10. rocket
    14,798
    2,344
    Jun 26, 2010
    connecticut
    Ram Year:
    2006 Nightrunner
    Engine:
    HEMI 5.7
    gotcha ...amsoil product. my only observation would be, if the original was so great.....how did /could they improve upon it?...no hate here.....a million drag racers can't be wrong.
Share This Page
