- May 8, 2017
- 3,029
- 3,880
- 2017
- Hemi 5.7
Has anyone tried tru fuel? Premixed premium, no Ethanol, synthetic 2 Stoke oil.Here is an interesting article. My suggestion don't pre mix a lot of gas for your 2 stroke stuff, and when you have gas stored at the one year mark put it in the truck and go get new gas. As far as our fuel tanks in our trucks, we should be running the tanks real low every once in a while? Have a gallon or 2 on board just in case when doing so.
It's expensive so if you use alot of 2 Stoke mix it wouldn't be fiesable, but I don't use that much. I had to fire the chain saw up this morning, it's been sitting for 5 years, not started, last gas run thru it was regular pump gas with generic 2 stroke oil and a couple ounces of Lucas ethanol treatment. I figured I'd spend half the day getting that thing running but I dumped out the little bit of old gas that was in it and filled it up with tru fuel and 4th or 5th pull she fired right up. It surprised the hell out of me. Had my sawing done in no time.
Sent from my XT1650 using Tapatalk
