Theoretically
Badger
Bettendorf, IA
Theoretically if I were to go drag my 4x4 should i launch in 4HI or 2HI
reefguy89
laurel de
i believe 2hi on these trucks are just regular driving. if your having traction issues you can launch in 4hi then shift out by 30mph.
Cthulhu
Calgary, AB
Cummins 5.9
So.. as long as you don't plan on going faster than 30mph down the dragstrip, 4lo will work... :birgits_tiredcoffee
reddot
Wolf Point, MT
5.9 cummins
4hi will give better traction, but you will have more power loss through the drivetrain. So if you can get traction in 2wd go with that but if you just cant hook up try 4 and I assume if you have shift on the fly you can shift out of it as you go down. Dont know what it takes for it to actually disengage but im sure someone knows.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I can't imagine shifting from 4wd to 2wd while trying to race would help or be good for drivetrain. I think you would be better off put some sand bags over rear axle even though you would add weight you would get more traction and hookup quicker.
$miley
