Thoughts on my 04 Ram 2500 build sheet
usocazy
San Antonio, Texas
Hemi 5.7l
So I got the build sheet on my 2004 Ram 2500. I always knew it was a heavy duty Hemi but what else can you tell me about the rest of the build? Transmission, gears, accessories, etc...
What's a XBSS ​Pickup Box?
What would a truck with the same build sheet go for today?
Vehicle Description: DODGE RAM 2500 QUAD CAB PICKUP
Model Year: 2004
Body Model: DR 2 H 41
Sales Code​Description
V9 ​Cloth 40/20/40 Bench Seat
DV ​Dark Slate Gray
AHC ​Trailer Tow Group
APAS ​Monotone Paint
A85P ​Mutually Exclusive Package
BAZS ​136 Amp Alternator
BCQP ​750 Amp Maintenance Free Battery
BRTS​Anti-Lock 4-Wheel Disc Brakes
CBEP ​40/20/40 Split Bench Seat
CFMP ​Rear Folding Seat
CGDS​ Front Height Adjust Shoulder Belts
CG1S ​Next Gen Multistage Front Air Bags
CKES ​Floor Covering Carpet
CLAS ​Front Floor Mats
CSPS ​Passenger Assist Handle
CUES ​Rear Underseat Compartment Storage
CUSS ​Overhead Console w/Trip Computer
DGES ​All 5-Speed Automatic Transmissions
DGQ ​5-Spd Automatic 545RFE Transmission
DHAP ​Lock-Up Torque Converter
DMES ​3.73 Rear Axle Ratio
DRWS ​10.50 Rear Axle
EAGC ​All Gas Engine
EZA ​5.7L V8 HEMI Engine
GACS​Tinted Glass Windows
GJDS ​Rear Fixed Window
GNAS ​Rear View Day/Night Mirror
GNMS ​Passenger Side Sun Visor w/Mirror
GPG ​Power Black Trailer Tow Mirrors
GVBC ​All Vehicles W/Power Mirrors
GXMS ​Remote Keyless Entry
HAAS ​Air Conditioning
HGBS ​Dash Liner Insulation
HGFS ​Floor Tunnel Insulation
I74S ​Route 74 - UP, Westfield, TX
JAYS ​Instrument Cluster w/Tach
JCBS ​120 MPH Primary Speedometer
JHAS ​Var Intermittent Windshield Wipers
JJAS ​Cigar Lighter
JJBS ​Dual Note Electric Horns
JJJS ​12V Auxiliary Power Outlet
JPBS ​Power Locks
JPDS ​Power Windows, Driver One-Touch
LBCS ​Glove Box Lamp
LMAS ​Halogen Headlamps
LNJ ​Fog Lamps
LPES ​Cargo Lamp
MBFS ​Bright Rear Bumper
MCMS ​Body Color Upper Fascia
MCTS ​Bright Front Bumper
MDAS ​Front License Plate Bracket
MFDS ​Bright Grille
MTDS ​SLT Badge
MURS ​Dodge Badge
MWDS ​Removable Tailgate w/Caliper Latches
MXBS ​Front Air Dam
MXCP ​Front Air Close Out Panel
NAS ​50 State Emissions
NBKP ​EVAP Control System
NFUS ​34 Gallon Fuel Tank
NHBP ​Auxiliary Transmission Oil Cooler
NHMS ​Speed Control
NHNP ​Electronically Controlled Throttle
NMCS ​Heavy Duty Engine Cooling
NZDP ​Next Generation Engine Controller
PX8A ​Black Clear Coat
QX8S ​Black Clear Coat
RAAC ​All Radio Equipped Vehicles
RBKS ​AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS​4 Speakers
RDDP ​Fixed Long Mast Antenna
SBAS ​Power Rack and Pinion Steering
SCV ​Leather Wrapped Steering Wheel
SFBS ​Front Heavy Duty Shock Absorbers
SGBS ​Rear Heavy Duty Shock Absorbers
SHAS ​Front Stabilizer Bar
SUAS ​Tilt Steering Column
TBBS ​Full Size Spare Tire
TBMS ​Tire Carrier Winch
TT3S ​LT265/70R17E BSW All Season Tires
TZHP ​Michelin Brand Tires
WF1S ​17" Steel Spare Wheel
WGSS ​17X8.0 Steel Chrome Clad Wheels
WLYC ​All Steel Wheels
WMJP ​Center Hub
XBSS ​Pickup Box
XFHP ​Class IV Receiver Hitch
XFKP ​7 Pin Wiring Harness
XFUS ​Trailer Tow w/4-Pin Connector Wiring
YAAS ​Build To U.S. Mkt. Specifications
SFD213
Well its all written right there. You have 3.73 gears which are good for towing and a 5 spd auto tranny (4 w/OD). Not sure if you have the 6 or 8 ft bed but sounds like you got the same package as meImageUploadedByTapatalk1406468683.173998.jpg
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
i hated the 3.73's in my 2500 for towing. They work great with a diesel, but with an HD hemi truck 4.56's are the way to go. Puts you right into the power band and makes towing a breeze.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Yeah, I was curious about the gears. My truck lacks the "umph" when cruising around and needing to take off quick off the line. Yes, I understand the 2500 is built for hauling but I do like the idea of getting more torque out of the Hemi during quick starts.
usaf2006
Augusta, GA
Not according to amazons "check your vehicle". How'd you find that one? Oh.. and check moes. Easy website to use and good prices.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Np. When I get my 4.56s theyll be from moes.
What's the level of effort to swap out gears? I'm pretty handy and did almost the entire front end myself along with various other preventive maintenance tasks (rotors, pads, shocks, spark plugs, cleaned throttle body, etc). All that to say, I'm not a certified mechanic but am a quick learner. Just don't want to jump into something beyond my abilities.
usaf2006
Augusta, GA
That I dont know. Im in your boat. Ive heard it is very particular and not for novices. Im too scared to do it myself lol. Check out some youtube videos. Im sure there are some good ones to learn from.
BowHunter96
What is the process of getting the build sheet on a truck?
