Throttle body intake manifold options
Discussion in 'Engine & Performance' started by dev199505, Dec 9, 2016.
Sponsored By: Moe's Performance
  1. dev199505
    dev199505 Member
    22
    59
    Dec 7, 2016
    Ram Year:
    1988
    Engine:
    5.2
    Just curious, can't find anything on Google, will a throttle body bolt to a standard carburator intake manifold?
    Sent from my Coolpad 3622A using Tapatalk
  2. crazzywolfie
    crazzywolfie Senior Member
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    nope. the throttle body has a slightly larger bolt pattern. you would need an adapter plate to make it work
  3. dev199505
    dev199505 Member
    22
    59
    Dec 7, 2016
    Ram Year:
    1988
    Engine:
    5.2
    Would I gave to make one or can I buy one
  4. crazzywolfie
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i am not sure. i think you might have to make one for that application. if you had a 4bbl it would be a lot easier but going from a 2bbl to a throttle body is a bit of a pain since the 2bbl has a smaller bolt pattern than the throttle body.
    [​IMG]
    [​IMG]
  5. dev199505
    dev199505 Member
    22
    59
    Dec 7, 2016
    Ram Year:
    1988
    Engine:
    5.2
    Would I run into issues if I did a 4 barrel carb swap?
  6. crazzywolfie
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    depends on whether your truck is setup for carb or TBI. if your truck is setup for TBI then it would be a lot more work and expensive since you would also have to buy all the ignition parts on top of the intake and carb.
  7. dev199505
    dev199505 Member
    22
    59
    Dec 7, 2016
    Ram Year:
    1988
    Engine:
    5.2
    Well TBI factory
  8. crazzywolfie
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
  9. dev199505
    dev199505 Member
    22
    59
    Dec 7, 2016
    Ram Year:
    1988
    Engine:
    5.2
    I found a bunch of adapters on there but they are all for Chevy lol, I don't plan on anywhere near 400hp so I feel that'd be overkill was thinking headers, single 2.5" header back exhaust, mild cam, and a k&n air filter an maybe ported and polished heads
  10. crazzywolfie
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    that kit is good for engines up to 400hp. it is just a cheaper replacement to the crappy stock setup. i am pretty sure it can be tuned to work with a cam unlike the stock TBI setup that you can do nothing with. the stock computer hates changes like a cam that is not stock. that kit can also be used to control electric fans if you decide to run those also.
Share This Page
