Tire Conversion Chart.
Discussion in 'Exterior' started by powerhour, Jul 16, 2010.
Sponsored By: BAK Factory Outlet
  1. powerhour
    powerhour Senior Member
    28
    259
    Jul 9, 2010
    Campbell River, BC
    Ram Year:
    Engine:
    3.6
    i hope this helps!
    225/85R 14 = 29 X 9.00 X 14
    215/75R 15 = 28 X 8.50 X 15
    215/85R 15 = 29 X 8.50 X 15
    225/75R 15 = 28 X 9 X 15
    235/75R 15 = 29 X 9 X 15
    325/60R 15 = 31 X 12.50 X 15
    Q78-15 = 35.50 X 11.00 X 15
    215/70R 16 = 28 X 8.50 X 16
    225/70R 16 = 28.50 X 9 X 16
    225/75R 16 = 30 X 9 X 16
    235/70R 16 = 29 X 9.50 X 16
    235/85R 16 = 32 X 9.50 X 16
    245/70R 16 = 30 X 10 X 16
    245/75R 16 = 31 X 10 X 16
    255/70R 16 = 30 X 10.50 X 16
    255/85R 16 = 33 X 10.50 X 16
    265/70R 16 = 31 X 10.50 X 16
    265/75R 16 = 32 X 10.50 X 16
    265/80R 16 = 32.50 X 10.00 X 16
    275/70R 16 = 31.50 X 11 X 16
    285/75R 16 = 33 X 11.50 X 16
    295/75R 16 = 33.50 X 12 X 16
    305/70R 16 = 33 X 12.50 X 16
    305/85R 16 = 36 X 11.50 X 16
    315/75R 16 = 35 X 12.50 X 16
    325/70R 16 = 34 X 13 X 16
    325/80R 16 = 37 X 13 X 16
    365/65R 16 = 35 X 14.50 X 16
    Q78-16 = 35.50 X 11.00 X 16
    265/70R 17 = 32 X 11.50 X 17
    275/70R 17 = 32.50 X 11.00 X 17
    285/70R 17 = 33 X 11.50 X 17
    295/70R 17 = 33 X 12.0 X 17
    305/70R 17 = 34 X 12.00 X 17
    315/70R 17 = 34.50 X 12 X 17
    255/55R 18 = 29 X 10.50 X 18
    285/60R 18 = 32 X 11 X 18
    285/65R 18 = 33 X 11.50 X 18
    325/60R 18 = 33 X 13 X 18
    325/65R 18 = 35 X 13 X 18
    355/65R 18 = 37 X 14 X 18
    305/50R 20 = 32 X 12.50 X 20
    305/55R 20 = 33 X 12.50 X 20
    325/60R 20 = 35 X 13.00 X 20
    355/60R20 = 36.50 X 14.00 X 20
    325/50R22 = 35 X 13.00 X 22
  2. glass3222
    glass3222 Senior Member
    37
    2,340
    Jul 2, 2010
    Central PA
    Ram Year:
    2005
    Engine:
    Good info.
    Or if you want to convert it yourself:
    1. take the first number (the width in millimeters) and divide by 25.4, this give you the width in inches
    2. multiply be the second number (aspect ratio) divide by 100 (percentage), this gives you the sidewall height
    3. multiply by 2, the add the 3rd number (wheel diameter)
    Example: 275/60 R20 (factory 20" Ram tires)
    1. 275/25.4= 10.82677 inches
    2. 10.82677*60/100 or 10.82677/.6 = 6.496 inches
    3. 6.496*2 = 12.992 + 20 = 32.992 = 33" tire height.
  3. Deviate
    Deviate Senior Member
    710
    31
    Jul 2, 2010
    St. Augustine, FL
    Ram Year:
    2005 4x2
    Engine:
    4.7
    That chart and formula will get you in the ballpark, but depending on the manufacturer the actual tire height will vary because of tread pattern or what have you. Case in point:
    265-70-17 AT tires:
    Formula Height: 31.61
    Nitto Terra Grappler actual height: 31.57
    BFG AT: 31.8
    Dick Cepek Radial F-C II: 31.7
    Not that a 10th of an inch makes that much real world difference, but just pointing that out.
  4. ramhunter9
    ramhunter9 Supporting Member
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    good info fellas .. stickie time
  5. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
  6. The Assassin
    The Assassin Supporting Member
    38
    7,725
    19
    Jul 8, 2010
    B-more careful, Murderland
    Ram Year:
    2006
    Engine:
    4.7
  7. xb1230
    xb1230 Senior Member
    950
    180
    Aug 22, 2014
    South Shore of Montreal, QC, Canada
    Ram Year:
    2002
    Engine:
    4.7L Magnum V8 (Semi-HEMI... Wishful thinking!)
    I personally like the one in the link below as it breaks down by rim and then overall tire diameter.
    Tire Size Conversion Chart
    It makes it easy to find alternate tire size that would fit your application as well as includes metric conversions.
    Sort of an All-in-one tool.
    Hope this helps
  8. warlock61
    warlock61 Junior Member
    Mar 13, 2015
    Ram Year:
    2006
    Engine:
Share This Page
