Tire size help needed..!
Discussion in 'Exterior' started by Magnum5.9, May 28, 2016.
Sponsored By: BAK Factory Outlet
  1. Magnum5.9
    Magnum5.9 Senior Member
    537
    65
    Aug 8, 2014
    Ram Year:
    01 ram 1500 4x4
    Engine:
    Magnum 5.9
    Looking to go from 285/75/16 to 275/60/20 or 305/55/20 or 275/65/20 but am concerned I may run into rubbing issues while at full suspension articulation if I don't get the offset/backspace just right. I have a 01 4x4 with 2" spacer with new coils and shocks in the front and stock setup in the rear
    Can anyone tell me what the biggest tire is that will not run with a 20" rims? I've searched around the sight but can't find too much info on a situation like mine. Thanks!
  2. Magnum5.9
    537
    65
    Aug 8, 2014
    Ram Year:
    01 ram 1500 4x4
    Engine:
    Magnum 5.9
    No thoughts?
  3. Magnum5.9
    537
    65
    Aug 8, 2014
    Ram Year:
    01 ram 1500 4x4
    Engine:
    Magnum 5.9
    As far as tires I am looking at Duatrac in load range C with those 20" rims. Or should I get with E?
  4. jknappen
    jknappen Senior Member
    494
    69
    Aug 27, 2013
    Kentucky
    Ram Year:
    Engine:
    I run cooper discoverer st maxx 275/65/20. E load range. No rubbing. I have a 2013
  5. crazzywolfie
    crazzywolfie Senior Member
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    you might have got more responses if you posted in the right section. it looks like you have a 2nd gen and you posted in the 1st gen section
Share This Page
