Tore up once again
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
Massive coolant loss looks to the the water pump hopefully ... once I fix it I just may see if it wants a new owner BTW ROLL MOTHER ******* TIDE!!!!!!!!!!!!!!!
AJMAG
new jersey
hopefully water pump and not head gasket. good luck man!
quietpeen
2021 TRX
Hellcat
awe man that sucks. Hope you get it fixed
BAMA BOY
BAMA BOY
Gasden,Alabama
Thanks fellas what's the symptoms of head gasket?
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
I changed my water pump on my 05', it's not too bad. Just couldn't get the old pulley off the old pump, so I had to buy the unit with a new pulley, just a little more $$$. Hope it's not a head gasket! Get in under the truck, and look around. See if you see anything bad, or that would indicate a more severe problem.
BAMA BOY
BAMA BOY
Gasden,Alabama
No smoke ... water pump down is soaked
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Luckly the front core support takes no time to get out of the way. I would suggest doing that to get to the water pump easier
BAMA BOY
BAMA BOY
Gasden,Alabama
Luckly just the radiator 2500 rpm and she's pressure washing
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Rad wont be bad to change out, less then an hour including refilling and burping.
