torque converter recomendations
jbmobbs
murfreesboro, tennessee
ok i want to replace my torque converter since it is old so can people please recomend some i want it to have a lil more torque and mpg.....help please
Hotroder383
Washington Mo
318 or 5.2 which ever you want
converters don't really "make" TQ or mpg, they just allow a highly modded engine to launch at a higher RPM range. But there may be some stock replacements out there that are better than others. I can't say as I have ever replaced one just because it was "old". Unless you are having trouble with it I'd say keep your money or spend it on a diff upgrade.
jbmobbs
jbmobbs
well i have 456 gears and a built tranny but lately its felt slugish on take off so i figured the t-converter was slowly going out
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
A quality tq converter does not add power, but it will reduce some of the tq loss that is caused by the sub par factory converter. Because of this, it will help at all rpms, but you will feel the biggest gain off the line.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Going to PM you in a minute.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i am running a patc 2600. it works pretty well. no major slipping on take off. just not fully locked till 2600 rpms. it was a pretty good investment. if you call patc they can build you want you want and help you in the right direction you should go. if i remember correctly stock is like 1900.
46re right?
V-10 RAM
Lee Vining CA
v-10
I'm not sure I agree with some on this issue. I had an 86 F250 4x4 460 C-6 3:55 gears. I installed a Hughes Tow Converter HD along with a 6 clutch forward clutch pak. Transgo shift kit. It gave me a big increase in torque pull a 10,000# TT. Climbing mountain passes really showed an increase.
But my 99 V-10 5 Sp 3:55 gears pulls circles around that Ford with the same trailer. Once you go DODGE you can never go back.
