Torque
Discussion in 'Engine & Performance' started by BiggRigg93, Mar 26, 2013.
Sponsored By: Moe's Performance
  1. BiggRigg93
    BiggRigg93 Junior Member
    24
    11
    Mar 18, 2013
    Minnesota
    Ram Year:
    Engine:
    Whats the easiest and cheapest way to increase torque? I have a 2011 5.7
  2. dusterman
    dusterman Senior Member
    137
    11
    Mar 21, 2013
    Ram Year:
    2012 express reg cab
    Engine:
    Let ask you a important question. What is your extra torque you used for. If get a answer for that we can give you some ideas
  3. jlb
    jlb Senior Member
    1,062
    93
    Mar 22, 2012
    MT
    Ram Year:
    2011 (2)
    Engine:
    Hemi 5.7, CTD
    Probably one of the best ways would be to get a tuner, and depending on why you want it, maybe lower gears.
  4. Chewy
    Chewy Senior Member
    2,366
    430
    Dec 7, 2012
    Bettendorf IA
    Ram Year:
    Engine:
    V8
    Pretty much the same way you add HP. CAI, exhaust, and a tuner.
    You could also go as far as head and intake plenum work, cam and headers.
    Chris
  5. fasthemiram12
    fasthemiram12 Senior Member
    33
    789
    192
    Mar 11, 2013
    Ram Year:
    Engine:
    Eagle 5.7 vvt
    Nitrous.... = lots of torque
    pond and Lawhand like this.
  6. Kaiser
    Kaiser Senior Member
    113
    Jun 24, 2012
    SD
    Ram Year:
    Engine:
    Are you looking for off idle torque? If so then I don't feel opening up the intake and exhaust is the way to go. When you do that more times than not you lose velocity of the air coming in and going out of the engine which will hurt your off idle torque. Those things may increase your peak HP and TQ but not at low RPM's. I'd look more into an efan, tuner to adjust timing, and like was mentioned earlier...gears.
  7. Hemi450hp
    Hemi450hp Moe's Performance
    9,162
    4,020
    Jul 17, 2012
    Conroe, TX
    Ram Year:
    2017 Ram 1500
    Engine:
    If you are looking for off the line tq, then you want to go to a 4.10 or 4.56 gear ratio out back and a higher stall converter.
Share This Page
