I will either put a 4.5" suspensions lift, block/torsion key lift with a 3" body lift on my truck eventually. But for now I wanted to try just cranking the torsion bar preload bolts. I forgot to measure the ride hight beforehand, but turned the bolts 3 turns and now the front sits at 37.5" (ground to top of the fender well). Its not too much rougher at all, but Im noticing a few new squeaks, is this something anyone else has noticed? Also would a key allow it to sit higher but keep the factory ride, or would it just allow more adjustment?
And would someone know the ride height stock? I recorded the length of the bolts so I can put it back, but Id still like to know how much height I gained without having to do that. Thank you
Edit: Im running the stock tire size if that matters to anyone (SLT 17" rims)
