dsent
- Nov 19, 2012
- 336
- 64
- Location
- SC
- 2012 2500HD 4x4 Crew Cab Laramie
- 6.7 cummins diesel
Hello Guys/Girls
After reading numerous post here on RAM Forum there seems to be some confusion what TOW/HAUL mode is
used for or does.
I have had numerous trucks by 2 different manufactures Dodge/Ram and Nissan that have had tow/haul mode equipped on them.
The tow/haul mode only changes the shift points, to allow more bottom end when starting out, it allows the transmission to stay in the lower gear longer before it shifts to help get the load moving.
If your concern is your transmission when you tow, turn off overdrive to stop the transmission from constantly hunting the higher gear.
Turn off the OVERDRIVE is smart practice especially when towing heavy!
Turning OFF OVERDRIVE while driving in city traffic stops the car/truck from shifting into OVERDRIVE at low speeds "LUGGING".
Shifting to overdrive at slow speeds is COSTING you MPG because you are "LUGGING" the motor,rather than it be in the proper gear!! When "LUGGING" along and you need to speed up your car/truck downshifts and uses more fuel.
This constant "Lugging" is hard on your motor and tranmission and burns more fuel.
Lugging an engine/ transmission is not a good practice and over time can cause some damages or shorten the life of your motor and trans do to heat and lack of lubrication at key points in your motor and trans.
Some engine and trans components are not pressure lubricated and is done by a rotating parts slinging the oil from a small cavity or resivoir in the motor and trans to put a film/mist of oil to key parts,LUGGING causes these slinging parts to not rotate at the proper RPM to sling enough oil to the places that depend/use this method to get lubed.
My 2500 has a button on the shifter arm I can limit the highest gear to any gear I need to, this stops the trans from hunting on steep accents when towing heavy in the mtns.
I have never had to use it yet, pulling 10,000 lbs but I can see it has an application and no doubt help pulling big loads.
GO CUMMINS!!
Hope this helps to explain things
used for or does.
GO CUMMINS!!
