Tow Hitch Upgrade?
Discussion in 'Towing & Hauling' started by Ronnyboy, Dec 29, 2012.
  1. Ronnyboy
    Ronnyboy Junior Member
    Nov 27, 2012
    Ram Year:
    1997
    Engine:
    5.2 Magnum
    So my 97 1500 only has the famous bumper mount and currently has the wiring and ball mount on it. I plan on taking some camping trips and hauling some bigger trailers this fall. What do you guys recommend for a frame mounted hitch? I was looking at all different brands and I have no idea where to start...
  2. SmokedRam
    SmokedRam Supporting Member
    38
    6,468
    433
    May 1, 2012
    Zephyrhills, Florida
    Ram Year:
    2005
    Engine:
    4.7
  3. MADDOG
    MADDOG Super Moderator Staff Member
    7,130
    1,880
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    You will need to know what the tongue weigh and loaded weight of the trailer. However, most trailers your truck can tow will fall into the Class III receiver hitch category. A Class IV is a nice upgrade and gives you some over - spec'd capacity if needed.
    That's a great website ^^^^ posted above. Here's one that explains the different classes and capacities:
    hitchesonline
  4. Ronnyboy
    Nov 27, 2012
    Ram Year:
    1997
    Engine:
    5.2 Magnum
    Thanks for the links guys! Will definetly hitting up the class IV one soon! Will I be needing the one for the deep drop bumper?
  5. Chewy
    Chewy Senior Member
    2,366
    430
    Dec 7, 2012
    Bettendorf IA
    Ram Year:
    Engine:
    V8
    I've pulled a 24' trailer loaded with a Cobra Replica with a class three. Class four isn't necessary unless pulling a small dozer or something! lol ;)
    Sent from my miniaturizer via tap dancing...
  6. Aries Rising
    Aries Rising Junior Member
    13
    Dec 23, 2016
    Ram Year:
    199?
    Engine:
    5.2
    Subscribed.
  7. alanack6795
    alanack6795 Member
    30
    Dec 12, 2016
    Ram Year:
    1994
    Engine:
    5.9L6
    I run the Curt class V 2400/16000 hitch on my diesel. Fits perfect and was less than $200 shipped .
    Looks like the price went up.
    http://www.rockauto.com/en/moreinfo.php?pk=4362978&cc=1095904&jnid=478&jpid=6
    In my gas half ton truck I run the factory tow package hitch that is rated for 7,000.
    It's rated for 10k with a WD hitch, if you pull over 7k without the WD hitch it will break, I broke the factory hitch on my diesel a long time ago
  8. bcbouy
    bcbouy Senior Member
    1,084
    398
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    get the highest class that'll fit,brand is irrelevant.no point in having "good enough". when it comes to towing,no such thing as overkill.even my front bottom hitch is a class 5. the top one is rated for 9k line pull,but i've surpassed that once or twice.
    alanack6795 and Markcuda like this.
Share This Page
