Towing for the 1st time
shawn1112
Streamwood IL
I have a 14 Laramie and plan on towing a 80 Malibu on a Uhaul car trailer this weekend. Total mileage will be about 300 miles. All my truck has is the hitch from the factory. What do I need to go buy, a hitch ball if so anything in particular to look for? Any pointers for my first time towing, 4wd or leave it in 2wd? Thanks in advance.
Andrew09HEMI
Hitch ball size depends on what the trailer requires, call uhaul and ask. 2wd is all you'll need unless you're in mud or snow. Factory hitch should be fine. Do you know weight of trailer and car?
Csanders1992
I believe all uhaul trailers require a 2" ball
UnsatFC
Active duty NAVY
New Jersey
I just got done using a uhaul auto transport a few weeks ago. They require this according to the website.
Hitch Balls
Hitch-ball sizes of 1-7/8 and 2 inches are acceptable with a U-Haul trailer coupler.
With the factory class 5 receiver you're good to go just get a 2" drop kit with 2" ball class III. They sell a kit at Uhaul with a lock on it for about $30. I just got that due to not being able to find any other kits that were rated for over 5,000 lbs. With the class III you will be good for 7,500 lbs.
Also 2wd with tow haul on would do just fine I would think.
billa9b0ng
2014 Ram 2500 SLT CCSB
Curious as to your plans for the Malibu... Do you mind sharing?
14hemiexpress
6.4l
Most U-Haul locations sell the hitch and ball. Check with them for the right ball size it's dependant on trailer. Towing nothing special just use tow haul. Give your self plenty of distance to stop U-Haul trailer should have surge brakes so no need for brake controller. Other than that just be smart and take your time speed and trailers gets you in trouble.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Agree with the others. Have u haul help you figure how much of a drop shank you need. You want the trailer level or slightly nose low when loaded. Take your time. Most trailer tires are speed rated to 65mph. I'd recommend you keep it 55-60 on the highway and enjoy the ride
SHOOT2KILL
2015...2500H.D.
If your truck came with a class 5 hitch that would be a 2.5" square opening...Dropping down to a class 4 or 3 rating only requires a 2" square opening...You will need to purchase the ball receiver accordingly....You should have received with the truck a factory sleeve that slides into the 2.5" opening allowing you to drop down to class 3 & 4 receiver size of 2" square...Read this link and set your truck up accordingly....
BTW...Go see my old pals at Advantage Trailer on North Av in Carol Stream,il...They will get you setup for a safe tow...
https://www.reese-hitches.com/learning_center/general-towing-classes
Sandbox
Warrenton, VA
6.4 HEMI
I can tell you from personal experience that if you have a 1500 with a Class IV hitch, if they are paying attention, they will likely tell you it's too heavy too be pulled with your truck. That Uhaul car trailer is like 2300lbs is I remember correctly.
You can always go to the Uhaul website, put in your truck info and what you plan to pull and it will tell you if Uhaul will let you do it.
SHOOT2KILL
2015...2500H.D.
https://www.ramtrucks.com/assets/towing_guide/pdf/2015_ram_1500_towing_charts.pdf
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
does you truck have brake controller if not don't tow it you will regret it the first time you have to stop fast. you are probably going to be north of 6000 lbs and unless I'm mistaken surge brakes wont handle that very well.
jacobsmudder
2014 1500 express 4x2 6at reg cab
I tow one of my cars a lot with uhaul trailers. all have been 1 7/8ths not 2inch. Agreed with previous poster to keep at 55-60. Had a trailer tire blow out once with a car on it and it was no fun. Lesson learned. Take your turns wide and use your mirrors.
Csanders1992
The trailers accept both sizes. But 2" is most common so he should get a 2" if he only buys one
S
shawn1112
Streamwood IL
Well both Malibu's I was seriously interested in sold last night and this morning. Kind of pissed as I told both sellers if they get a better offer to contact me and if it was doable I would Paypal them a deposit. So back to the search.
Plans were just a street cruiser with the occasional track visit. More than likely would have done a 383 stroker crate motor. Kicked around the idea of an LS swap but would really like to keep the motor as original as possible. Was hoping to be at or around 400-450 hp to the crank. Respectable paint and interior as well.
S
shawn1112
Streamwood IL
I used their website and it said I was fine
VLG6963
