Track bar drop bracket
Dmopar74
I see pure performance has a 3" track bar drop bracket for our newer hd trucks, has any body used one yet?
King nothing
Central IL
Cummins
Do you have a drop pitman arm? Whatever you do to the trac bar you also have to do to the steering or you will get bad bumpsteer
D
Dmopar74
I did not know that.
Phil21502
Frostburg, MD
Yeah the trac bar and drag link should stay in parallel lines to avoid bump steer
SwollenMonkey16
Hmmmm there's plenty of guys on here doing a 2.5-3" lift with track bar upgrades and no pitman arm upgrade maybe they can chime in
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
That I know of, the 2.5 - 3" lifts with a track bar, it's just a longer front track bar. This is to re-center the axle. I haven't seen any 3" or smaller lifts with a drop bracket. Doesn't mean they don't exist, but I haven't seen any.
Thuren makes a rear trackbar & bracket kit for 0-2.5" rear lifts.
King nothing
Central IL
Cummins
They might be upgrading the trac bar with a longer/adjustable unit but they aren’t dropping the frame end
SwollenMonkey16
So just to clarify, (2-3" lifts) if its a Trac bar upgrade then you don't need a pitman arm but if you instead use a drop bracket then you need to upgrade to a drop Pitnam arm?
Phil21502
Frostburg, MD
Yes. Whatever u do the trac bar u need to do to the drag link too. Like in this case if u drop the trac bar u need to drop the drag link which is done with a longer pitman arm.
SwollenMonkey16
Thanks ill remember that bc I'm on the fence between a 3" and a 4"
King nothing
Central IL
Cummins
Yes. However a 2-3 inch lift should not require a pitman or trac bar drop. Dropping them might actually cause clearance problems. Most of the time you don’t drop the pitman or trac bar until you’re over 4 inches of lift
