Hmmmm there's plenty of guys on here doing a 2.5-3" lift with track bar upgrades and no pitman arm upgrade maybe they can chime in
So just to clarify, (2-3" lifts) if its a Trac bar upgrade then you don't need a pitman arm but if you instead use a drop bracket then you need to upgrade to a drop Pitnam arm?
Yes. Whatever u do the trac bar u need to do to the drag link too. Like in this case if u drop the trac bar u need to drop the drag link which is done with a longer pitman arm.
