Redtruck-VA
- Jun 29, 2010
- 5,864
- 984
- Location
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
We often hear about trans failures and more than likely mulitiple failures with the guys making big horsepower. And we assume it is the horsepower burning them up. But I haven't heard about anyone actually breaking anything, just burning clutches leading to failure. So my question comes to this, is it possible that the problem isn't with the trans physically handling the power, but being the result of our tuning strategy? The trans line pressure (clutch pressure) is varied to reduce parasitic loss from the pump. The MAP and TPS provide critical signals to the PCM/TCM to determine "load" , The problem is we tune for the engine, often pulling fuel to make the engine run correctly. This modified signal I believe has a direct side effect of signalling that there is a lower load than is actually present reducing "line pressure" and the clutches slip causing failure. There is of course the Transgo and Sonnax line boosters that can be installed to modify the signal voltage (5v) a given percentage of the sensor's actual signal. I am thinking perhaps a better solution is to take control of the signal and fix it at constant voltage to maintain high line pressure to hold the clutches. This might even be something a window switch can control using rpm as the determining factor for line pressure rather the load calculations done by the TCM.
Your experiences and/or thoughts on this are welcomed.
