Trans failures
RAMpage
Kentucky
custom 5.7/6.1 hemi hybrid
yeah i think imma go ahead and get the deep pan with it just to keep it a little cooler and upgrade the trans cooler to a bigger efan unit. that price doesnt include the labor. what do you guys think about using that raptor blood tranny fluid? its on the same page as the link closer to the bottom.
Redtruck-VA
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Take a look at post #52...
Edit: Two problems I have with the deep aluminum pans. 1. If you are lowered you lose ground clearance. 2. If you hit an aluminum pan or a differential cover for that matter it will likely be broken were a steel one will just get bent up.
05 2500 HD trans cooler p/n 52029089ab
frostking
3rd problem: Nobody makes a filter extension so all deep pans are useless without one.
adamwilkes14
just food for thought....if the Raptor Blood runs so much cooler than reg ATF..it would kind of eliminate the need to run a deeper pan, would it not, especially with a better trans oil cooler?
frostking
I doubt the temperature would change. Even on my truck I use the stock small 2WD transmission pan with the factory light duty cooler and only have the problem of the transmission being too cold for where it should be. <160*F
Off-roading likely would place a higher demand on the cooling system.
adamwilkes14
I inquired about getting my trans beefed up for towing in my second gen. When I asked about the deeper pan the rebuilder said that in like 98 Chrysler actually went to a deeper factory pan and that it was more than sufficient. Really dont know whats in yalls though as far as size .
Redtruck-VA
Redtruck-VA
Virginia
I use the OEM 2500HD unit and have never had a issue with trans heat even stuck in summer traffic. My thought was the engine radiator would be the weak link as horsepower was added. Apparently I've not done much to strain it. I use a 180 degree stat and Black Magic eFan with the controller set at 190 degrees. Although if I was doing a eFan again I would use either a Taurus or Viper fan only because they are in my opinion more robust and replacement motors readily available.
