My transfer case is leaking from the rear output shaft seal. I've replaced the seal and the leak remains. I'm assuming that the sealing surface on the slip yoke is pitted or imperfect in some way. I found an output shaft repair sleeve by Timken, part # KWK99187, ordered it and got it today. Figure to install it this weekend. I opened the box and its two parts, one sleeve with a lip around it, I know this goes over the shaft. The other part looks like a cup that the sleeve fits into. I assume that this is a tool to press the sleeve? There are no instructions with the sleeve.
Has anyone ever installed one of these that can shed some light on how to install it without ruining the seal, sleeve or slip yoke?
