Jimmy68
- Aug 30, 2015
- 1,419
- 645
- Location
- Lethbridge Alberta Canada
- 2001
- 5.2L Magnum
I have an 01 1500 auto with a
2001-98 23 spline input, 32 spline rear slip, w/o speedo hole, manual shift, flat circular front output yoke. .840 exposed input. A/T NP231D.
I have a T-case from a 94 2500 auto and I have not dug out the shed to access the T-case yet but it could be one of two. Hopefully the NP241 DHD. But will either of these work if it is not?
1997-94 23 spline input, 32 spline slip rear, flat circular front output. w/speedo hole. 1.550 inch exposed input shaft NP241DLD.
1997-94 23 spline front input, 32 spline rear slip output, 1. 375 O.D., w/P.T.O., w/1.750 inch speedo hole, .840 inch exposed input shaft NP241DHD.
Thank you, Jimmy.
Thank you, Jimmy.
