transmission cooler line
Discussion in 'General Discussion' started by LaurenMagnum360, Feb 7, 2014.
  1. LaurenMagnum360
    LaurenMagnum360 Senior Member
    28
    238
    59
    Feb 6, 2014
    Illinois
    Ram Year:
    2001
    Engine:
    360 V8
    So guys, i picked up a 2001 Ram 1500 with the 5.9 the other day, and first thing i noticed is it has a brand new radiator, but only the external transmission cooler is hooked up. So i went to the dealer and bought the trans cooler hose, and the quick disconnect coupler...
    Hose P/n : 4883317ab
    connector P/n : 52028625AC
    i slipped the connector onto the hose, and now it won't come off.
    my question is, does this get crimped like the other side of the hose, or not?
    The dealer couldn't answer me, because they had never seen this before. But yet i bought it from them, oem mopar parts.
    Thanks
    [​IMG]
  2. Merc225hp
    Merc225hp Senior Member
    5,141
    3,118
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    No it does not get crimped like the other end, once its on you need a disconnect tool to remove it from the line.
    Redtruck-VA and LaurenMagnum360 like this.
  3. LaurenMagnum360
    28
    238
    59
    Feb 6, 2014
    Illinois
    Ram Year:
    2001
    Engine:
    360 V8
    thanks, already have the disconnect tool. next question, the fitting is missing the 'spring' clip thingy that goes inside it. any idea where to get that?
    thanks for being the only one to respond to my previous question :party36:
  4. Merc225hp
    5,141
    3,118
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    Sorry I am lost a bit on this one, if you have an old one post up a pix if you can.
  5. luigi38
    luigi38 Junior Member
    Feb 8, 2014
    Ram Year:
    1999
    Engine:
    5.9
    Hi guys,
    New here, I just picked up a 99 1500 5.9, and trans fuild is leaking from the passenger front, which seems to be the lines from the trans to the trans cooler or rad.
    What tool did you get the disconnect the lines? Did you rent it?
  6. Merc225hp
    5,141
    3,118
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
  7. Redtruck-VA
    Redtruck-VA Senior Member
    5,372
    692
    Virginia
    Ram Year:
    2003 & 1989 D250 RWD
    Engine:
    Maybe a picture will help, there really isn't a lot in those connectors.
  8. LaurenMagnum360
    28
    238
    59
    Feb 6, 2014
    Illinois
    Ram Year:
    2001
    Engine:
    360 V8
    i found a clip. i had to buy a complete other connector and steal the clip from it lol. its the 4 prong clip inside the connector that mates with the ridge on the 3/8" transmission line
  9. quadcab
    quadcab Member
    32
    97
    11
    Oct 12, 2013
    Ram Year:
    2001
    Engine:
    360 Magnum
    Hes referring to the retainer clip. However I would advise not hooking that cooler line up. What probably happened was the truck suffered a catastrophic transmission failure and debris got all inside the cooling system. So the stock cooler was bypassed and am external cooler hooked up in its place.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  10. quadcab
    quadcab Member
    32
    97
    11
    Oct 12, 2013
    Ram Year:
    2001
    Engine:
    360 Magnum
    At least flush it out first.
Share This Page
