Transmission pan drain plug install.
R.L.K.
Bristol , Tn.
Helo all , I'm gonna be dropping my XSMN pan soon for fluid and filters change . I'd like to install a drain plug .
Where have you guys sourced them from , how much $$ and are you happy with it ?
Things most important to me is a good sealing non leaking install that is low profile inside and out of the drain pan .
Any other insight you'd like to share on the pan drop / reinstall and filter replacement is welcome ...
Thanks for a response !
Hemi395
Cape Cod MA
I bought a B&M drain plug for my truck but haven't put it in yet. Haven't put it in yet so I can't say how well it works but I've been happy with B&M products over the years.
R.L.K.
R.L.K.
Bristol , Tn.
This may be Rediclous , but if I had a drain for my xsmn pan I'd change the fluid probably @15k intervals and filters every 45 or so ...
I know this sounds crazy but I've had xsmn problems in the past and this may or may not fix that issue but I don't think it would hurt ....?
Hemi395
Cape Cod MA
Changing trans fluid more often is never a bad thing. Unless you have the 8 speed, changing the trans fluid is cheap insurance. I'm looking at changing my fluid and filters when my truck hits 20k. While I have the pan off I want to put my plug in so I can drop the fluid more often
smoothee
St. John's, NL
I'll probably just end up buying a deeper pan with a drain plug in it when the times comes. Although they aren't exactly giving them away...
R.L.K.
R.L.K.
Bristol , Tn.
Where did you find the pan @ and how much $ $ was it ?
Hemi395
Cape Cod MA
Mag Hytec has one that is $300. It has cooling fins and a drain plug built in but I can't see spending that kind of money on a trans pan. Theres a couple of others out there for around $2-250 but thats all I found. Thats why I ended up going with the plug kit for $10
smoothee
St. John's, NL
Yeah I could justify it more if I were changing it every 10k or something. Hell, even 50k.
R.L.K.
R.L.K.
Bristol , Tn.
Well I guess if I needed to spend $300 on something I'd get a cooler looking larger capacity pan with a drain plug , but for now I'll just be getting a drain plug kit for <$10.00 !
Thanks for all the responses !
beep119
R.L.K. So did you install the tranny drain plug? How did it go, which did you use?
Any videos you watch for advice?
R.L.K.
R.L.K.
Bristol , Tn.
No Sir , I ended up getting a Mag-Hyteck pan with a drain plug . I highly recommend this pan !!
CarKnockerJim
Martin TN
whats different with the 8 speed?
The filter is also part of the pan on the 8sp,so to do a filter change you're stuck buying a new tranny pan.PPE has stepped up and has a tranny pan that utilizes a replacement filter,so after the first really expensive tranny fluid/filter swap it's not quite as expensive
TallBoy1969
Woodville, Texas
Question!!! What is the # of the 6 spd trans?
I was looking to purchase a filter set to change it all and could not find a 6 speed for 2012 where I was looking
Will it be the same as the 6 speed for 2013??
Hemi395
Cape Cod MA
The Mopar filters for the RFE transmission are 05179267AC and 5013470AC
