Transmission Question
Discussion in 'Towing & Hauling' started by Idahobushpilot, Sep 10, 2016.
  1. Idahobushpilot
    Idahobushpilot Junior Member
    May 29, 2016
    Ram Year:
    2006
    Engine:
    Cummins
    I have a 2006 Ram 2500 with diesel power and a 5 speed auto trans. 123,000 miles. The truck is like new and has been maintained endlessly. I have noticed since moving to Idaho and pulling long, steep, and winding grades pulling my 8000 lb camp trailer
    ( yesterdays grade was 7 miles ) about 3/4 the way up the transmission will start dropping from 2nd gear to 3rd then quickly to 4th at a speed of about 20 mph. At this point the speed will slow and when I give it additional throttle the trans will then kick up to 2nd but when the speed increases a small amount I go thru the same process. This happens regardless if I am in normal or towing mode. Sure does not seem normal and sinse it starts to happen after extended pulling up steep grades it makes me worry. Any help is appreciated.
  2. Bullitt5339
    Bullitt5339 Senior Member
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    Can you monitor transmission temperatures? Transmission heat when towing, especially on steep grades is the enemy and the #1 killer of tow vehicles.
Share This Page
