Transmission swap compatabilty
Discussion in '2nd Gen DIY' started by jackson4212, Jan 12, 2017.
  1. jackson4212
    jackson4212 Junior Member
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    I own a 1998 Dodge Ram 1500 2wd Laramie and a 1999 Dodge Ram van 3500 2wd. I was wondering if the transmission in the van is the same as the truck and I could swap them out. The transmission went out on the van and the frame of the van is badly rusted through on the front end. It has several other issues and its not really worth the effort because of the crap frame. I was considering removing the transmission before I junk the van to rebuild. Never done it before but thought it would be fun to learn.
    Can they be swapped?
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,509
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    They will bolt right up as long as they are both either the 5.9 or 5.2. Wait for dapepper to tell you which pieces you need to swap, if you need to swap.
  3. dapepper9
    dapepper9 Senior Member
    22
    4,873
    1,873
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    5.2/5.9 v8s are swappable. 8.0 v10/5.9 diesel to the v8s not possible.
    98 46re to 99 46re only issue is going to be flexplate for correct engine and this isn't an issue if both are 5.9 v8s
  4. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    Would the 5.2 have a flate plate I could put on the trans from the 5.9?
  5. dapepper9
    22
    4,873
    1,873
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Just to verify, van is a 5.2 v8 and the 3500 is a 5.9 v8 correct?
    If that's the case, to use the 5.2 trans you would need to use the 5.9 flexplate, which you should have in the 3500 already
  6. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    The van is a 5.9 and I would be moving that trans to a 5.2
  7. dapepper9
    22
    4,873
    1,873
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Well the 5.2 flexplate then. Not a big deal
  8. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    Is the flex plate already on the truck I'm moving it to?
  9. dapepper9
    22
    4,873
    1,873
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Should. If the trans and stuff in the 5.2 hasn't been pulled it'll have it. Otherwise your guess is good as mine lol
Share This Page
