Transmission Temp Gauge
dapepper9
Iowa/Nebraska Border
5.9L V8
So I recently installed a transmission temperature gauge so as to have a better idea of what is going on inside. Decided to make this write up after it was requested lol.
I'm going to start out by saying that my install will be different than most. The reason being is I have a deeper aftermarket pan with a drain plug and a pre-drilled and tapped sensor port. However I will provide the info to do it without an aftermarket sensor port or pan.
Things you'll need:
-Gauge, I went with GlowShift for looks and low price
-means to mount it, I went with a single pod A-pillar mount also from GlowShift
-Extra wire, to connect to the power and ground wires on the gauge to the battery, switched power, ground, and the optional dimmer power
-Butt connectors/solder equipment, to make all the connections
-Drill
-1/8" drill bit
-3/8 to 1/2" drill bit
-Phillips drill bit
To start, connect the quick plugs to the gauge and mount it into the pod. Just slides in, pretty tight. Then drill 4 holes, 1 in each corner, of the pod using the 1/8" bit. Now pop off the stock a-pillar and use the pod as a template to drill 4 more holes in the a-pillar for the screws included in the gauge kit. Will look like this when put together. 4 black dots are the screw caps that came included as well.
Next drill a hole with the bigger bit in the center of those 4 holes, should look like the 5 side of a pair of dice. This bigger hole is where the wires will go through the a-pillar. Run the gauge wires through the hole and splice some longer wire for each lead (orange wire on my kit gets spliced into headlight switch, dims the gauge 30% when headlights are on, optional and I didn't do it). Red is power, white is switched power (key on power, like the radio), and black is ground. Run the now longer wires down the A-pillar and out through the fuse panel.
Red power wire will go under the dash and through the firewall to the battery, or you can find another constant power source to splice into. Supposed to install a fuse as well but I neglected to. Oops. Ground I took one of the nuts off where the steering column bolts to the firewall and slipped an eyelet over one of the studs. I've used this point before so I knew it was a good ground. White switched power I spliced into an add-a-fuse I had for my LED lighting inside, plugged into the radio fuse.
Thicker black cord for the sensor will follow, down the a-pillar, out the firewall and down the engine bay. Skirt past the exhaust and follow the trans down to the sensor that i installed in the port when i swapped my valvebody prior.
dapepper9
dapepper9
5.9L V8
Sits pretty close to the front driveshaft but I tied it up away with zip ties.
Now. Connect sensor to the cord, snap a-pillar back in, make sure you don't have loose hanging wires that will get caught somewhere, and you're done. Pretty self explanatory, white to white, black to black. Test drive it get it warmed up and see if she works.
If you don't have an aftermarket pan with a port, GlowShift has a test port adapter. What this does is plugs into the test port on the PASSENGER side of the trans, above the valvebody, and the sensor will plug right into it.
Linky
The cord from the gauge SHOULD reach. I had extra cord to work with on the driverside, enough that I'm pretty sure I could reach the passenger side. I tied it up inside the dash to keep it out of the way.
Jrock2394
5.2 V8
Nice write-up. Il be putting mine in the test port when it comes in. Think it's gonna go in the accumulator test port.
tommyboi87
houma louisiana
5.2 Magnum
Spot on buddy. Good job adding the test port. That's where I hooked mine in, instead of buying the pan.
Sent from my SAMSUNG-SM-G925A using Tapatalk
tommyboi87
houma louisiana
5.2 Magnum
Have an update on the setup? How's the temp reading at the pan? Oh another question, we've got the same gauge. How long does it take for the gauge to register temp?
dapepper9
dapepper9
5.9L V8
Temp at the pan tells me what temp it is before cycling through the trans which is nice. Being in iowa it takes a while right now before i register a temp because it's cold af outside lol. Works great though
tommyboi87
houma louisiana
5.2 Magnum
I've got the same problem. Takes a good 10 minutes before I show an accurate temp. It's a slow rise until it starts to read.
USAFoffroad1999
Nor-Cal
5.9 V-8
So i just read through your install , and i had one question/request could you get a pic of the test port . When i look on my trans i see 3 plugs and i wouldt want to pull the wrong one . Just in case, my truck is 99 1500 5.9 (360) auto
dapepper9
dapepper9
5.9L V8
I didn't use the test port on mine as I have an aftermarket pan. My port in my pan is on the driverside however the factory test port is on the passenger. Look through the download of the factory service manual, there's a diagram in there if i remember correctly.
Edit: page 21-488
tommyboi87
houma louisiana
5.2 Magnum
Kinda late, but this is the test port I'm installed on.
