Tried to fuel pumps
bozeblake
The line is clear to pump and has gas. Can you put pump in wrong?
Sent from my XT1585 using Tapatalk
bozeblake
bozeblake
That was supposed to be tried two fu pumps
Sniper X
What year and motor?
crazzywolfie
under the truck
have you tried tried blowing into the fuel line to to see if anything in the tank is possibly blocked?
i think it is possible to put the fuel pump in wrong. you need the get the are in under the lobe on the cam. if you are sure you are getting the pump in right then there is the possibility that the lobe on the cam is possibly gone.
