Trouble code list recals and TSB's
Discussion in 'Tech Info' started by ramhunter9, Jun 27, 2010.
Thread Status:
Not open for further replies.
  1. ramhunter9
    ramhunter9 Supporting Member
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    P0A00 - P0A29
    P0A00 Motor Electronics Coolant Temp Sens Circ
    P0A01 Motor Electronics Coolant Temp Sens Circ Range/Perf
    P0A02 Motor Electronics Coolant Temp Sens Circ Low
    P0A03 Motor Electronics Coolant Temp Sens Circ Hi
    P0A04 Motor Electronics Coolant Temp Sens Circ Interm
    P0A05 Motor Electronics Coolant Pump Ctrl Circ/Open
    P0A06 Motor Electronics Coolant Pump Ctrl Circ Low
    P0A07 Motor Electronics Coolant Pump Ctrl Circ Hi
    P0A08 DC/DC Conv Status Circ
    P0A09 DC/DC Conv Status Circ Low Input
    P0A10 DC/DC Conv Status Circ Hi Input
    P0A11 DC/DC Conv Enable Circ/Open
    P0A12 DC/DC Conv Enable Circ Low
    P0A13 DC/DC Conv Enable Circ Hi
    P0A14 Engine Mount Ctrl Circ/Open
    P0A15 Engine Mount Ctrl Circ Low
    P0A16 Engine Mount Ctrl Circ Hi
    P0A17 Motor Torque Sens Circ
    P0A18 Motor Torque Sens Circ Range/Perf
    P0A19 Motor Torque Sens Circ Low
    P0A20 Motor Torque Sens Circ Hi
    P0A21 Motor Torque Sens Circ Interm
    P0A22 Generator Torque Sens Circ
    P0A23 Generator Torque Sens Circ Range/Perf
    P0A24 Generator Torque Sens Circ Low
    P0A25 Generator Torque Sens Circ Hi
    P0A26 Generator Torque Sens Circ Interm
    P0A27 Battery Power Off Circ
    P0A28 Battery Power Off Circ Low
    P0A29 Battery Power Off Circ Hi
  2. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1000 - P1099
    P1000 Ignition Circ Low
    P1001 Ignition Circ Hi
    P1004 ECU Battery Feed & Power Grounds
    P1005 Sys Ground Circ
    P1006 EGR/EVAP Solenoid Circ Low
    P1007 EGR/EVAP Solenoid Circ Hi
    P1008 Power Steering Circ Low
    P1009 Power Steering Circ Hi
    P1012 MPA Circ Low
    P1013 MPA Circ Hi
    P1014 Fuel Pump Circ Low
    P1015 Fuel Pump Circ Hi
    P1016 Charge Air Temp Circ Low
    P1017 Charge Air Temp Circ Hi
    P1018 Serial Data Circ
    P1019 Power Latch Not Set
    P1021 Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
    P1022 Starter Relay Circ Low
    P1024 ECU Start Circ Low
    P1025 WOT Circ Low
    P1026 WOT Circ Hi
    P1027 ECU Sees Wide Open Throttle
    P1028 ECU Does Not See Wide Open Throttle
    P1029 ISA Closed Throttle Circ Low
    P1030 ISA Closed Throttle Circ Hi
    P1031 ECU Sees Closed Throttle
    P1032 ECU Does Not See Closed Throttle
    P1033 ISA Circs
    P1037 TP Sens Circ Reads Low
    P1038 Park/Neutral Line Hi
    P1039 Park/Neutral Line Low
    P1040 Latched B+ Line Low
    P1041 Latched B+ Line Hi
    P1042 No Latched B+ 1/2 Volt Drop
    P1043 Shift Lamp Circ Grounded
    P1044 D2–1 Circ Low (A/T) or
    P1044 Upshift Lamp Circ (M/T) or
    P1044 Shift Lamp Circ Hi
    P1045 Shift Lamp Circ Open
    P1047 Wrong ECU
    P1048 M/T Vehicle Configuration
    P1049 A/T Vehicle Configuration
    P1050 Idle RPM Low
    P1051 Idle RPM Hi
    P1052 MAP Sens Out Of Limits
    P1053 Change In MAP Reading Out Of Limits
    P1054 Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
    P1055 Coolant Sens Circ Hi
    P1056 Inactive Coolant Temp Sens
    P1059 A/C Request Circ Low
    P1060 A/C Request Circ Hi
    P1061 A/C Select Circ Low
    P1062 A/C Select Circ Hi
    P1063 A/C Clutch Circ Low
    P1064 A/C Clutch Circ Hi & Power Steering Input
    P1068 Latch Relay Circ Hi
    P1069 No Tach
    P1074 ECU Does Not See Speed Sens
  3. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1100 - P1199
    P1106 MAP Sens Circ Interm Hi Voltage
    P1107 MAP Sens Circ Interm Low Voltage
    P1110 Decreased Engine Perf Due To Hi Intake Air Temp
    P1111 IAT Sens Circ Interm Hi Voltage
    P1112 IAT Sens Circ Interm Low Voltage
    P1114 ECT Sens Circ Interm Low Voltage
    P1115 ECT Sens Circ Interm Hi Voltage
    P1121 TPS Circ Interm Hi Voltage
    P1122 TPS Circ Interm Low Voltage
    P1125 Accelerator Pedal Pos Sys
    P1133 HO2S Insufficient Switching Bank1 Sens1
    P1134 HO2S Insufficient Transition Time Ratio Bank1 Sens1
    P1153 HO2S Insufficient Switching Bank2 Sens1
    P1154 HO2S Insufficient Transition Time Ratio Bank2 Sens1
    P1180 Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
    P1191 Intake Air Duct Leak
    P1192 Inlet Air Temp Sens Voltage Low
    P1193 Inlet Air Temp Voltage Hi
    P1194 02 Heater Perf
    P1195 1/1 02 Sens Slow During Catalyst Monitor
    P1196 2/1 02 Sens Slow During Catalyst Monitor
    P1197 1/2 02 Sens Slow During Catalyst Monitor
    P1198 Radiator Temp Sens Volts Too Hi
    P1199 Radiator Temp Sens Volts Too Low
  4. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1200 - P1299
    P1214 Inj Pump Timing Offset
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Inj Pump Calibration Circ
    P1271 Accelerator Pedal Pos Sens1-2 Correlation
    P1272 Accelerator Pedal Pos Sens2-3 Correlation
    P1273 Accelerator Pedal Pos Sens1-3 Correlation
    P1275 Accelerator Pedal Pos Sens1 Circ
    P1277 Accelerator Pedal Pos Sens1 Low Voltage
    P1278 Accelerator Pedal Pos Sens1 Hi Voltage
    P1280 Accelerator Pedal Pos Sens2 Circ
    P1281 Engine is Cold Too Long
    P1282 Accelerator Pedal Pos Sens2 Low Voltage
    P1282 Fuel Pump Relay Ctrl Circ or
    P1283 Accelerator Pedal Pos Sens2 Hi Voltage
    P1283 Idle Select Signal Invalid or
    P1284 Fuel Inj Pump Battery Voltage Out Of Range
    P1285 Accelerator Pedal Pos Sens3 Circ
    P1285 Fuel Inj Pump Ctrller Always On or
    P1286 Accelerator Pos Sens Supply Voltage Too Hi
    P1287 Accelerator Pedal Pos Sens3 Low Voltage
    P1287 Fuel Inj Pump Ctrl Supply Voltage Low or
    P1288 Accelerator Pedal Pos Sens3 Hi Voltage
    P1288 Intake Manif Short Runner Solenoid Circ or
    P1289 Manif Tune Valve Solenoid Circ
    P1290 CNG Fuel Sys Press Too Hi
    P1291 No Temp Rise Seen From Intake Heaters
    P1292 CNG Press Sens Voltage Too Hi
    P1293 CNG Press Sens Voltage Too Low
    P1294 Target Idle Not Reached
    P1295 No 5Vs to Throttle Pos Sens
    P1296 No 5Vs to MAP Sens
    P1297 No Change in MAP from Start To Run
    P1298 Lean Operation at Wide Open Throttle
    P1299 Vacuum Leak Found (IAC Fully Seated)
  5. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1300 - P1399
    P1336 Crank Pos Sys Variation Not Learned
    P1345 Crank Pos/Camshaft Pos Correlation
    P1351 Ignition Ctrl Circ Hi Voltage
    P1361 Ignition Ctrl Circ Low Voltage
    P1380 Electronic Brake Ctrl Rough Road Data Unusable
    P1381 Misfire Detected-No Electronic Brake Ctrl Data
    P1388 Auto Shutdown Relay Ctrl Circ
    P1389 No ASD Relay Output Voltage at PCM
    P1390 Timing Belt Skipped 1 Tooth or More
    P1391 Interm Loss of CMP or CKP
    P1398 Misfire Adaptive Numerator at Limit
    P1399 Wait to Start Lamp Circ
  6. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1400 - P1499
    P1403 No 5Vs to EGR Sens
    P1404 EGR Valve Closed Pintle Pos
    P1406 EGR Valve Pos
    P1409 EGR Valve Sys leak
    P1415 AIR Sys Bank1
    P1416 AIR Sys Bank1
    P1441 Evap Emissions Flow During Non-Purge
    P1475 Auxiliary 5V Supply Voltage Hi
    P1476 Too Little Sec Air
    P1477 Too Much Sec Air
    P1478 Battery Temp Sens Volts Out of Limit
    P1479 Trans Fan Relay Circ
    P1480 PCV Solenoid Circ
    P1481 EATX Misfire RPM Signal out of Range
    P1482 Catalyst Temp Sens Circ Shorted Low
    P1483 Catalyst Temp Sens Circ Shorted Hi
    P1484 Catalytic Conv Overheat Detected
    P1485 Air Inj Solenoid Circ
    P1486 Eva Leak Monitor Pinched Hose Found
    P1487 Hi Speed Radiator Fan CTRL Relay Circ
    P1488 Auxiliary 5V Supply Output Too Low
    P1489 Hi Speed Fan CTRL Relay Circ
    P1490 Low Speed Fan CTRL Relay Circ
    P1491 Radiator Fan Ctrl Relay Circ
    P1492 Ambient/Battery Temp Sens Volts Too Hi
    P1493 Ambient/Battery Temp Sens Volts Too Low
    P1494 Leak Detection Pump Switch or Mechanical Fault
    P1495 Leak Detection Pump Solenoid Circ
    P1496 5V Supply, Output Too Low
    P1498 Hi Speed Radiator Fan Ground CTRL Relay Circ
  7. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1500 - P1599
    P1508 IAC Sys Low RPM
    P1509 IAC Sys Hi RPM
    P1594 Charging Sys Voltage Too Hi
    P1595 Speed Ctrl Solenoid Circs
    P1596 Speed Ctrl Switch Always Hi
    P1597 Speed Ctrl Switch Always Low
    P1598 A/C Press Sens Volts Too Hi
    P1599 A/C Press Sens Volts Too Low
  8. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1600 - P1699
    P1602 PCM Not Programmed
    P1621 PCM Memory Perf or Write
    P1626 Vehicle Theft Sys Ctrl Loss of Data
    P1627 A/D Perf
    P1630 Vehicle Theft Sys PCM in Learn Mode
    P1631 Vehicle Theft Sys Improper Password
    P1635 5V Ref ( Circ
    P1639 5V Ref ( Circ
    P1641 MIL Ctrl Circ
    P1643 Wait To Start Lamp Ctrl Circ
    P1646 5V Ref (C) Circ
    P1652 J1850 Comms Bus
    P1653 EGR Vent Solenoid Ctrl Circ
    P1654 Service Throttle Soon Lamp Ctrl Circ
    P1655 EGR Solenoid Ctrl Circ
    P1656 Wastegate Solenoid Ctrl Circ
    P1680 Clutch Released Switch Circ
    P1681 No I/P Cluster CCD/J1850 Messages Received
    P1682 Charging Sys Voltage Too Low
    P1683 Speed Ctrl Power Relay; or S/C 12v Driver CKT
    P1684 Battery Disconnected in the last 50 Starts
    P1685 Skim Invalid Key
    P1686 No SKIM BUS Messages Received
    P1687 No Cluster BUS Message
    P1688 Internal Fuel Inj Pump Ctrller Failure
    P1689 No Comm between ECM & Inj Pump Mod
    P1690 CKP Sens Does Not Agree with ECM CKP Sens
    P1691 Fuel Sys ESS RPM Error
    P1692 DTC Set In ECM
    P1693 DTC Detected in Companion JTEC Mod
    P1694 No BUS Message Received from ECM Mod
    P1695 No CCD/J1850 Messages from the Body Ctrl Mod.
    P1696 PCM Failure EEPROM Write Denied
    P1697 PCM Failure SRI Mile Not Stored
    P1698 No CCD/J1850 Message From TCM/PCM
  9. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P1700 - P1799
    P1719 Skip Shift Solenoid Circ
    P1740 TCC or O/D Solenoid Perf
    P1756 Gov Press Not Equal to Target @ not15-20 PSI
    P1757 Gov Press above 3 PSI in gear with 0 MPH
    P1762 Gov Press Sens Offset Volts Too Low or Hi
    P1763 Governor Press Sens Volts Too Hi
    P1764 Governor Press Sens Volts Too Low
    P1765 Trans 12 Volt Supply Relay CTRL Circ
    P1800 - P1899
    P1899 P/N Switch Stuck in Park or in Gear
  10. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P2000 - P2099
    P2000 NOx Trap Eff Below Threshold Bank1
    P2001 NOx Trap Eff Below Threshold Bank2
    P2002 Particulate Trap Eff Below Threshold Bank1
    P2003 Particulate Trap Eff Below Threshold Bank2
    P2004 Intake Manif Runner Ctrl Stuck Open Bank1
    P2005 Intake Manif Runner Ctrl Stuck Open Bank2
    P2006 Intake Manif Runner Ctrl Stuck Closed Bank1
    P2007 Intake Manif Runner Ctrl Stuck Closed Bank2
    P2008 Intake Manif Runner Ctrl Circ/Open Bank1
    P2009 Intake Manif Runner Ctrl Circ Low Bank1
    P2010 Intake Manif Runner Ctrl Circ Hi Bank1
    P2011 Intake Manif Runner Ctrl Circ/Open Bank2
    P2012 Intake Manif Runner Ctrl Circ Low Bank2
    P2013 Intake Manif Runner Ctrl Circ Hi Bank2
    P2014 Intake Manif Runner Pos Sens/Switch Circ Bank1
    P2015 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank1
    P2016 Intake Manif Runner Pos Sens/Switch Circ Low Bank1
    P2017 Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
    P2018 Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
    P2019 Intake Manif Runner Pos Sens/Switch Circ Bank2
    P2020 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank2
    P2021 Intake Manif Runner Pos Sens/Switch Circ Low Bank2
    P2022 Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
    P2023 Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
    P2024 EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
    P2025 EVAP Fuel Vapor Temp Sens Perf
    P2026 EVAP Fuel Vapor Temp Sens Circ Low Voltage
    P2027 EVAP Fuel Vapor Temp Sens Circ Hi Voltage
    P2028 EVAP Fuel Vapor Temp Sens Circ Interm
    P2029 Fuel Fired Heater Disabled
    P2030 Fuel Fired Heater Perf
    P2031 Exhaust Gas Temp Sens Circ Bank1 Sens2
    P2032 Exhaust Gas Temp Sens Circ Low Bank1 Sens2
    P2033 Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
    P2034 Exhaust Gas Temp Sens Circ Bank2 Sens2
    P2035 Exhaust Gas Temp Sens Circ Low Bank2 Sens2
    P2036 Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
    P2037 Reductant Inj Air Press Sens Circ
    P2038 Reductant Inj Air Press Sens Circ Range/Perf
    P2039 Reductant Inj Air Press Sens Circ Low Input
    P2040 Reductant Inj Air Press Sens Circ Hi Input
    P2041 Reductant Inj Air Press Sens Circ Interm
    P2042 Reductant Temp Sens Circ
    P2043 Reductant Temp Sens Circ Range/Perf
    P2044 Reductant Temp Sens Circ Low Input
    P2045 Reductant Temp Sens Circ Hi Input
    P2046 Reductant Temp Sens Circ Interm
    P2047 Reductant Injector Circ/Open Bank1 Unit 1
    P2048 Reductant Injector Circ Low Bank1 Unit 1
    P2049 Reductant Injector Circ Hi Bank1 Unit 1
    P2050 Reductant Injector Circ/Open Bank2 Unit 1
    P2051 Reductant Injector Circ Low Bank2 Unit 1
    P2052 Reductant Injector Circ Hi Bank2 Unit 1
    P2053 Reductant Injector Circ/Open Bank1 Unit 2
    P2054 Reductant Injector Circ Low Bank1 Unit 2
    P2055 Reductant Injector Circ Hi Bank1 Unit 2
    P2056 Reductant Injector Circ/Open Bank2 Unit 2
    P2057 Reductant Injector Circ Low Bank2 Unit 2
    P2058 Reductant Injector Circ Hi Bank2 Unit 2
    P2059 Reductant Inj Air Pump Ctrl Circ/Open
    P2060 Reductant Inj Air Pump Ctrl Circ Low
    P2061 Reductant Inj Air Pump Ctrl Circ Hi
    P2062 Reductant Supply Ctrl Circ/Open
    P2063 Reductant Supply Ctrl Circ Low
    P2064 Reductant Supply Ctrl Circ Hi
    P2065 Fuel Level Sens B Circ
    P2066 Fuel Level Sens B Perf
    P2067 Fuel Level Sens B Circ Low
    P2068 Fuel Level Sens B Circ Hi
    P2069 Fuel Level Sens B Circ Interm
    P2070 Intake Manif Tuning (IMT) Valve Stuck Open
    P2071 IMT Valve Stuck Closed
    P2075 IMT Valve Pos Sens/Switch Circ
    P2076 IMT Valve Pos Sens/Switch Circ Range/Perf
    P2077 IMT Valve Pos Sens/Switch Circ Low
    P2078 IMT Valve Pos Sens/Switch Circ Hi
    P2079 IMT Valve Pos Sens/Switch Circ Interm
    P2080 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
    P2081 Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
    P2082 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
    P2083 Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
    P2084 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
    P2085 Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
    P2086 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
    P2087 Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
    P2088 A Camshaft Pos Actuator Ctrl Circ Low Bank1
    P2089 A Camshaft Pos Actuator Ctrl Circ Hi Bank1
    P2090 B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
    P2091 B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
    P2092 A Camshaft Pos Actuator Ctrl Circ Low Bank2
    P2093 A Camshaft Pos Actuator Ctrl Circ Hi Bank2
    P2094 B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
    P2095 B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
    P2096 Post Catalyst Fuel Trim Sys Too Lean Bank1
    P2097 Post Catalyst Fuel Trim Sys Too Rich Bank1
    P2098 Post Catalyst Fuel Trim Sys Too Lean Bank2
    P2099 Post Catalyst Fuel Trim Sys Too Rich Bank2
Thread Status:
Share This Page
