trouble code list
Discussion in 'Tech Info' started by ramhunter9, Jun 27, 2010.
Thread Status:
Not open for further replies.
  1. ramhunter9
    ramhunter9 Supporting Member
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    P2100 - P2199
    P2100 Throttle Actuator Ctrl Motor Circ/Open
    P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
    P2102 Throttle Actuator Ctrl Motor Circ Low
    P2103 Throttle Actuator Ctrl Motor Circ Hi
    P2104 Throttle Actuator Ctrl Sys-Forced Idle
    P2105 Throttle Actuator Ctrl Sys-Forced Engine Shutdown
    P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
    P2107 Throttle Actuator Ctrl Mod Processor
    P2108 Throttle Actuator Ctrl Mod Perf
    P2109 Throttle/Pedal Pos Sens A Minimum Stop Perf
    P2110 Throttle Actuator Ctrl Sys-Forced Limited RPM
    P2111 Throttle Actuator Ctrl Sys-Stuck Open
    P2112 Throttle Actuator Ctrl Sys-Stuck Closed
    P2113 Throttle/Pedal Pos Sens B Minimum Stop Perf
    P2114 Throttle/Pedal Pos Sens C Minimum Stop Perf
    P2115 Throttle/Pedal Pos Sens D Minimum Stop Perf
    P2116 Throttle/Pedal Pos Sens E Minimum Stop Perf
    P2117 Throttle/Pedal Pos Sens F Minimum Stop Perf
    P2118 Throttle Actuator Ctrl Motor Current Range/Perf
    P2119 Throttle Actuator Ctrl Throttle Body Range/Perf
    P2120 Throttle/Pedal Pos Sens/Switch D Circ
    P2121 Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
    P2122 Throttle/Pedal Pos Sens/Switch D Circ Low Input
    P2123 Pedal Pos Sens1 Hi
    P2124 Throttle/Pedal Pos Sens/Switch D Circ Interm
    P2125 Throttle/Pedal Pos Sens/Switch E Circ
    P2126 Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
    P2127 Pedal Pos Validation Switch 2 Low
    P2128 Pedal Pos Validation Switch 2 Hi
    P2129 Throttle/Pedal Pos Sens/Switch E Circ Interm
    P2130 Throttle/Pedal Pos Sens/Switch F Circ
    P2131 Throttle/Pedal Pos Sens/Switch F Circ Range Perf
    P2132 Throttle/Pedal Pos Sens/Switch F Circ Low Input
    P2133 Throttle/Pedal Pos Sens/Switch F Circ Hi Input
    P2134 Throttle/Pedal Pos Sens/Switch F Circ Interm
    P2135 Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
    P2136 Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
    P2137 Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
    P2138 Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
    P2139 Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
    P2140 Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
    P2141 Exhaust Gas Recirculation Throttle Ctrl Circ Low
    P2142 Exhaust Gas Recirculation Throttle Ctrl Circ Hi
    P2143 Exhaust Gas Recirculation Vent Ctrl Circ/Open
    P2144 Exhaust Gas Recirculation Vent Ctrl Circ Low
    P2145 Exhaust Gas Recirculation Vent Ctrl Circ Hi
    P2146 Fuel Injector Group 1 Supply Voltage Circ
    P2147 Fuel Injector Group 1 Supply Voltage Low
    P2148 Fuel Injector Group 1 Supply Voltage Hi
    P2149 Fuel Injector Group 2 Supply Voltage Circ
    P2150 Fuel Injector Group 2 Supply Voltage Low
    P2151 Fuel Injector Group 2 Supply Voltage Hi
    P2152 Fuel Injector Group C Supply Voltage Circ/Open
    P2153 Fuel Injector Group C Supply Voltage Circ Low
    P2154 Fuel Injector Group C Supply Voltage Circ Hi
    P2155 Fuel Injector Group D Supply Voltage Circ/Open
    P2156 Fuel Injector Group D Supply Voltage Circ Low
    P2157 Fuel Injector Group D Supply Voltage Circ Hi
    P2158 Vehicle Speed Sens B
    P2159 Vehicle Speed Sens B Range/Perf
    P2160 Vehicle Speed Sens B Circ Low
    P2161 Vehicle Speed Sens B Interm/Erratic
    P2162 Vehicle Speed Sens A / B Correlation
    P2163 Throttle/Pedal Pos Sens A Maximum Stop Perf
    P2164 Throttle/Pedal Pos Sens B Maximum Stop Perf
    P2165 Throttle/Pedal Pos Sens C Maximum Stop Perf
    P2166 Throttle/Pedal Pos Sens D Maximum Stop Perf
    P2167 Throttle/Pedal Pos Sens E Maximum Stop Perf
    P2168 Throttle/Pedal Pos Sens F Maximum Stop Perf
    P2169 Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
    P2170 Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
    P2171 Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
    P2172 Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
    P2173 Throttle Actuator Ctrl Sys-Hi Airflow Detected
    P2174 Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
    P2175 Throttle Actuator Ctrl Sys-Low Airflow Detected
    P2176 Throttle Actuator Ctrl Sys-Idle Pos Not Learned
    P2177 Sys Too Lean Off Idle Bank1
    P2178 Sys Too Rich Off Idle Bank1
    P2179 Sys Too Lean Off Idle Bank2
    P2180 Sys Too Rich Off Idle Bank2
    P2181 Cooling Sys Perf
    P2182 Engine Coolant Temp Sens2 Circ
    P2183 Engine Coolant Temp Sens2 Circ Range/Perf
    P2184 Engine Coolant Temp Sens2 Circ Low
    P2185 Engine Coolant Temp Sens2 Circ Hi
    P2186 Engine Coolant Temp Sens2 Circ Interm/Erratic
    P2187 Sys Too Lean at Idle Bank1
    P2188 Sys Too Rich at Idle Bank1
    P2189 Sys Too Lean at Idle Bank2
    P2190 Sys Too Rich at Idle Bank2
    P2191 Sys Too Lean at Hier Load Bank1
    P2192 Sys Too Rich at Hier Load Bank1
    P2193 Sys Too Lean at Hier Load Bank2
    P2194 Sys Too Rich at Hier Load Bank2
    P2195 O2 Sens Signal Stuck Lean Bank1 Sens1
    P2196 O2 Sens Signal Stuck Rich Bank1 Sens1
    P2197 O2 Sens Signal Stuck Lean Bank2 Sens1
    P2198 O2 Sens Signal Stuck Rich Bank2 Sens1
    P2199 Intake Air Temp Sens1 / 2 Correlation
  2. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2200 - P2299
    P2200 NOx Sens Circ Bank1
    P2201 NOx Sens Circ Range/Perf Bank1
    P2202 NOx Sens Circ Low Input Bank1
    P2203 NOx Sens Circ Hi Input Bank1
    P2204 NOx Sens Circ Interm Input Bank1
    P2205 NOx Sens Heater Ctrl Circ/Open Bank1
    P2206 NOx Sens Heater Ctrl Circ Low Bank1
    P2207 NOx Sens Heater Ctrl Circ Hi Bank1
    P2208 NOx Sens Heater Sense Circ Bank1
    P2209 NOx Sens Heater Sense Circ Range/Perf Bank1
    P2210 NOx Sens Heater Sense Circ Low Input Bank1
    P2211 NOx Sens Heater Sense Circ Hi Input Bank1
    P2212 NOx Sens Heater Sense Circ Interm Bank1
    P2213 NOx Sens Circ Bank2
    P2214 NOx Sens Circ Range/Perf Bank2
    P2215 NOx Sens Circ Low Input Bank2
    P2216 NOx Sens Circ Hi Input Bank2
    P2217 NOx Sens Circ Interm Input Bank2
    P2218 NOx Sens Heater Ctrl Circ/Open Bank2
    P2219 NOx Sens Heater Ctrl Circ Low Bank2
    P2220 NOx Sens Heater Ctrl Circ Hi Bank2
    P2221 NOx Sens Heater Sense Circ Bank2
    P2222 NOx Sens Heater Sense Circ Range/Perf Bank2
    P2223 NOx Sens Heater Sense Circ Low Bank2
    P2224 NOx Sens Heater Sense Circ Hi Bank2
    P2225 NOx Sens Heater Sense Circ Interm Bank2
    P2226 Barometric Press Circ
    P2227 Barometric Press Circ Range/Perf
    P2228 Barometric Press Circ Low
    P2229 Barometric Press Circ Hi
    P2230 Barometric Press Circ Interm
    P2231 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
    P2232 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
    P2233 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
    P2234 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
    P2235 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
    P2236 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
    P2237 O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
    P2238 O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
    P2239 O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
    P2240 O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
    P2241 O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
    P2242 O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
    P2243 O2 Sens Ref Voltage Circ/Open Bank1 Sens1
    P2244 O2 Sens Ref Voltage Perf Bank1 Sens1
    P2245 O2 Sens Ref Voltage Circ Low Bank1 Sens1
    P2246 O2 Sens Ref Voltage Circ Hi Bank1 Sens1
    P2247 O2 Sens Ref Voltage Circ/Open Bank2 Sens1
    P2248 O2 Sens Ref Voltage Perf Bank2 Sens1
    P2249 O2 Sens Ref Voltage Circ Low Bank2 Sens1
    P2250 O2 Sens Ref Voltage Circ Hi Bank2 Sens1
    P2251 O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
    P2252 O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
    P2253 O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
    P2254 O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
    P2255 O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
    P2256 O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
    P2257 Sec Air Inj Sys Ctrl A Circ Low
    P2258 Sec Air Inj Sys Ctrl A Circ Hi
    P2259 Sec Air Inj Sys Ctrl B Circ Low
    P2260 Sec Air Inj Sys Ctrl B Circ Hi
    P2261 T/Super Charger Bypass Valve-Mechanical
    P2262 Turbo Boost Press Not Detected-Mechanical
    P2263 T/Super Charger Boost Sys Perf
    P2264 Water in Fuel Sens Circ
    P2265 Water in Fuel Sens Circ Range/Perf
    P2266 Water in Fuel Sens Circ Low
    P2267 Water in Fuel Sens Circ Hi
    P2268 Water in Fuel Sens Circ Interm
    P2269 Water in Fuel Condition
    P2270 O2 Sens Signal Stuck Lean Bank1 Sens2
    P2271 O2 Sens Signal Stuck Rich Bank1 Sens2
    P2272 O2 Sens Signal Stuck Lean Bank2 Sens2
    P2273 O2 Sens Signal Stuck Rich Bank2 Sens2
    P2274 O2 Sens Signal Stuck Lean Bank1 Sens3
    P2275 O2 Sens Signal Stuck Rich Bank1 Sens3
    P2276 O2 Sens Signal Stuck Lean Bank2 Sens3
    P2277 O2 Sens Signal Stuck Rich Bank2 Sens3
    P2278 O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
    P2279 Intake Air Sys Leak
    P2280 Air Flow Restriction / Air Leak Between Air Filter and MAF
    P2281 Air Leak Between MAF and Throttle Body
    P2282 Air Leak Between Throttle Body and Intake Valves
    P2283 Injector Ctrl Press Sens Circ
    P2284 Injector Ctrl Press Sens Circ Range/Perf
    P2285 Injector Ctrl Press Sens Circ Low
    P2286 Injector Ctrl Press Sens Circ Hi
    P2287 Injector Ctrl Press Sens Circ Interm
    P2288 Injector Ctrl Press Too Hi
    P2289 Injector Ctrl Press Too Hi-Engine Off
    P2290 Injector Ctrl Press Too Low
    P2291 Injector Ctrl Press Too Low-Engine Cranking
    P2292 Injector Ctrl Press Erratic
    P2293 Fuel Press Regulator 2 Perf
    P2294 Fuel Press Regulator 2 Ctrl Circ
    P2295 Fuel Press Regulator 2 Ctrl Circ Low
    P2296 Fuel Press Regulator 2 Ctrl Circ Hi
    P2297 O2 Sens Out of Range During Deceleration Bank1 Sens1
    P2298 O2 Sens Out of Range During Deceleration Bank2 Sens1
    P2299 Brake Pedal Pos / Accelerator Pedal Pos Incompatible
  3. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2300 - P2399
    P2300 Ignition Coil A Primary Ctrl Circ Low
    P2301 Ignition Coil A Primary Ctrl Circ Hi
    P2302 Ignition Coil A Sec Circ
    P2303 Ignition Coil B Primary Ctrl Circ Low
    P2304 Ignition Coil B Primary Ctrl Circ Hi
    P2305 Ignition Coil B Sec Circ
    P2306 Ignition Coil C Primary Ctrl Circ Low
    P2307 Ignition Coil C Primary Ctrl Circ Hi
    P2308 Ignition Coil C Sec Circ
    P2309 Ignition Coil D Primary Ctrl Circ Low
    P2310 Ignition Coil D Primary Ctrl Circ Hi
    P2311 Ignition Coil D Sec Circ
    P2312 Ignition Coil E Primary Ctrl Circ Low
    P2313 Ignition Coil E Primary Ctrl Circ Hi
    P2314 Ignition Coil E Sec Circ
    P2315 Ignition Coil F Primary Ctrl Circ Low
    P2316 Ignition Coil F Primary Ctrl Circ Hi
    P2317 Ignition Coil F Sec Circ
    P2318 Ignition Coil G Primary Ctrl Circ Low
    P2319 Ignition Coil G Primary Ctrl Circ Hi
    P2320 Ignition Coil G Sec Circ
    P2321 Ignition Coil H Primary Ctrl Circ Low
    P2322 Ignition Coil H Primary Ctrl Circ Hi
    P2323 Ignition Coil H Sec Circ
    P2324 Ignition Coil I Primary Ctrl Circ Low
    P2325 Ignition Coil I Primary Ctrl Circ Hi
    P2326 Ignition Coil I Sec Circ
    P2327 Ignition Coil J Primary Ctrl Circ Low
    P2328 Ignition Coil J Primary Ctrl Circ Hi
    P2329 Ignition Coil J Sec Circ
    P2330 Ignition Coil K Primary Ctrl Circ Low
    P2331 Ignition Coil K Primary Ctrl Circ Hi
    P2332 Ignition Coil K Sec Circ
    P2333 Ignition Coil L Primary Ctrl Circ Low
    P2334 Ignition Coil L Primary Ctrl Circ Hi
    P2335 Ignition Coil L Sec Circ
    P2336 Cylinder #1 Above Knock Threshold
    P2337 Cylinder #2 Above Knock Threshold
    P2338 Cylinder #3 Above Knock Threshold
    P2339 Cylinder #4 Above Knock Threshold
    P2340 Cylinder #5 Above Knock Threshold
    P2341 Cylinder #6 Above Knock Threshold
    P2342 Cylinder #7 Above Knock Threshold
    P2343 Cylinder #8 Above Knock Threshold
    P2344 Cylinder #9 Above Knock Threshold
    P2345 Cylinder #10 Above Knock Threshold
    P2346 Cylinder #11 Above Knock Threshold
    P2347 Cylinder #12 Above Knock Threshold
  4. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2400 - P2499
    P2400 EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
    P2401 EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
    P2402 EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
    P2403 EVAP Emission Sys Leak Detection Pump Sense Circ/Open
    P2404 EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
    P2405 EVAP Emission Sys Leak Detection Pump Sense Circ Low
    P2406 EVAP Emission Sys Leak Detection Pump Sense Circ Hi
    P2407 EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
    P2408 Fuel Cap Sens/Switch Circ
    P2409 Fuel Cap Sens/Switch Circ Range/Perf
    P2410 Fuel Cap Sens/Switch Circ Low
    P2411 Fuel Cap Sens/Switch Circ Hi
    P2412 Fuel Cap Sens/Switch Circ Interm/Erratic
    P2413 Exhaust Gas Recirculation Sys Perf
    P2414 O2 Sens Exhaust Sample Error Bank1 Sens1
    P2415 O2 Sens Exhaust Sample Error Bank2 Sens1
    P2416 O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
    P2417 O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
    P2418 EVAP Emission Sys Switching Valve Ctrl Circ /Open
    P2419 EVAP Emission Sys Switching Valve Ctrl Circ Low
    P2420 EVAP Emission Sys Switching Valve Ctrl Circ Hi
    P2421 EVAP Emission Sys Vent Valve Stuck Open
    P2422 EVAP Emission Sys Vent Valve Stuck Closed
    P2423 HC Adsorption Catalyst Eff Below Threshold Bank1
    P2424 HC Adsorption Catalyst Eff Below Threshold Bank2
    P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
    P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
    P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
    P2428 Exhaust Gas Temp Too Hi Bank1
    P2429 Exhaust Gas Temp Too Hi Bank2
    P2430 Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
    P2431 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
    P2432 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
    P2433 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
    P2434 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
    P2435 Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
    P2436 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
    P2437 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
    P2438 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
    P2439 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
    P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
    P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
    P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
    P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
    P2444 Sec Air Inj Sys Pump Stuck On Bank1
    P2445 Sec Air Inj Sys Pump Stuck Off Bank1
    P2446 Sec Air Inj Sys Pump Stuck On Bank2
    P2447 Sec Air Inj Sys Pump Stuck Off Bank2
  5. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2500 - P2599
    P2500 Generator Lamp/L-Terminal Circ Low
    P2501 Generator Lamp/L-Terminal Circ Hi
    P2502 Charging Sys Output Voltage
    P2503 Charging Sys Output Voltage Low
    P2504 Charging Sys Output Voltage Hi
    P2505 ECM/PCM Power Input Signal
    P2506 ECM/PCM Power Input Signal Range/Perf
    P2507 ECM/PCM Power Input Signal Low
    P2508 ECM/PCM Power Input Signal Hi
    P2509 CM/PCM Power Input Signal Interm
    P2510 ECM/PCM Power Relay Sense Circ Range/Perf
    P2511 ECM/PCM Power Relay Sense Circ Interm
    P2512 Event Data Recorder Request Circ/ Open
    P2513 Event Data Recorder Request Circ Low
    P2514 Event Data Recorder Request Circ Hi
    P2515 A/C Refrigerant Press Sens B Circ
    P2516 A/C Refrigerant Press Sens B Circ Range/Perf
    P2517 A/C Refrigerant Press Sens B Circ Low
    P2518 A/C Refrigerant Press Sens B Circ Hi
    P2519 A/C Request A Circ
    P2520 A/C Request A Circ Low
    P2521 A/C Request A Circ Hi
    P2522 A/C Request B Circ
    P2523 A/C Request B Circ Low
    P2524 A/C Request B Circ Hi
    P2525 Vacuum Reservoir Press Sens Circ
    P2526 Vacuum Reservoir Press Sens Circ Range/Perf
    P2527 Vacuum Reservoir Press Sens Circ Low
    P2528 Vacuum Reservoir Press Sens Circ Hi
    P2529 Vacuum Reservoir Press Sens Circ Interm
    P2530 Ignition Switch Run Pos Circ
    P2531 Ignition Switch Run Pos Circ Low
    P2532 Ignition Switch Run Pos Circ Hi
    P2533 Ignition Switch Run/Start Pos Circ
    P2534 Ignition Switch Run/Start Pos Circ Low
    P2535 Ignition Switch Run/Start Pos Circ Hi
    P2536 Ignition Switch Accessory Pos Circ
    P2537 Ignition Switch Accessory Pos Circ Low
    P2538 Ignition Switch Accessory Pos Circ Hi
    P2539 Low Press Fuel Sys Sens Circ
    P2540 Low Press Fuel Sys Sens Circ Range/Perf
    P2541 Low Press Fuel Sys Sens Circ Low
    P2542 Low Press Fuel Sys Sens Circ Hi
    P2543 Low Press Fuel Sys Sens Circ Interm
    P2544 Torque Management Request Input Signal A
    P2545 Torque Management Request Input Signal A Range/Perf
    P2546 Torque Management Request Input Signal A Low
    P2547 Torque Management Request Input Signal A Hi
    P2548 Torque Management Request Input Signal B
    P2549 Torque Management Request Input Signal B Range/Perf
    P2550 Torque Management Request Input Signal B Low
    P2551 Torque Management Request Input Signal B Hi
    P2552 Throttle/Fuel Inhibit Circ
    P2553 Throttle/Fuel Inhibit Circ Range/Perf
    P2554 Throttle/Fuel Inhibit Circ Low
    P2555 Throttle/Fuel Inhibit Circ Hi
    P2556 Engine Coolant Level Sens/Switch Circ
    P2557 Engine Coolant Level Sens/Switch Circ Range/Perf
    P2558 Engine Coolant Level Sens/Switch Circ Low
    P2559 Engine Coolant Level Sens/Switch Circ Hi
    P2560 Engine Coolant Level Low
    P2561 A/C Ctrl Mod Requested MIL Illumination
    P2562 Turbocharger Boost Ctrl Pos Sens Circ
    P2563 Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
    P2564 Turbocharger Boost Ctrl Pos Sens Circ Low
    P2565 Turbocharger Boost Ctrl Pos Sens Circ Hi
    P2566 Turbocharger Boost Ctrl Pos Sens Circ Interm
    P2567 Direct Ozone Reduction Catalyst Temp Sens Circ
    P2568 Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
    P2569 Direct Ozone Reduction Catalyst Temp Sens Circ Low
    P2570 Direct Ozone Reduction Catalyst Temp Sens Circ Hi
    P2571 Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
    P2572 Direct Ozone Reduction Catalyst Deterioration Sens Circ
    P2573 Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
    P2574 Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
    P2575 Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
    P2576 Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
    P2577 Direct Ozone Reduction Catalyst Eff Below Threshold
  6. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2600 - P2699
    P2600 Coolant Pump Ctrl Circ/Open
    P2601 Coolant Pump Ctrl Circ Range/Perf
    P2602 Coolant Pump Ctrl Circ Low
    P2603 Coolant Pump Ctrl Circ Hi
    P2604 Intake Air Heater A Circ Range/Perf
    P2605 Intake Air Heater A Circ/Open
    P2606 Intake Air Heater B Circ Range/Perf
    P2607 Intake Air Heater Relay 2 Low
    P2608 Intake Air Heater Relay 2 Hi
    P2609 Intake Air Heater Sys Perf
    P2610 ECM/PCM Internal Engine Off Timer Perf
    P2611 A/C Refrigerant Distribution Valve Ctrl Circ/Open
    P2612 A/C Refrigerant Distribution Valve Ctrl Circ Low
    P2613 A/C Refrigerant Distribution Valve Ctrl Circ Hi
    P2614 Camshaft Pos Signal Output Circ/Open
    P2615 Camshaft Pos Signal Output Circ Low
    P2616 Camshaft Pos Signal Output Circ Hi
    P2617 Crank Pos Signal Output Circ/Open
    P2618 Crank Pos Signal Output Circ Low
    P2619 Crank Pos Signal Output Circ Hi
    P2620 Throttle Pos Output Circ/Open
    P2621 Throttle Pos Output Circ Low
    P2622 Throttle Pos Output Circ Hi
    P2623 Injector Ctrl Press Regulator Circ/Open
    P2624 Injector Ctrl Press Regulator Circ Low
    P2625 Injector Ctrl Press Regulator Circ Hi
    P2626 O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
    P2627 O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
    P2628 O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
    P2629 O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
    P2630 O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
    P2631 O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
    P2632 Fuel Pump B Ctrl Circ /Open
    P2633 Fuel Pump B Ctrl Circ Low
    P2634 Fuel Pump B Ctrl Circ Hi
    P2635 Fuel Pump A Low Flow / Perf
    P2636 Fuel Pump B Low Flow / Perf
    P2637 Torque Management Feedback Signal A
    P2638 Torque Management Feedback Signal A Range/Perf
    P2639 Torque Management Feedback Signal A Low
    P2640 Torque Management Feedback Signal A Hi
    P2641 Torque Management Feedback Signal B
    P2642 Torque Management Feedback Signal B Range/Perf
    P2643 Torque Management Feedback Signal B Low
    P2644 Torque Management Feedback Signal B Hi
    P2645 A Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2646 A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2647 A Rocker Arm Actuator Sys Stuck On Bank1
    P2648 A Rocker Arm Actuator Ctrl Circ Low Bank1
    P2649 A Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2650 B Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2651 B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2652 B Rocker Arm Actuator Sys Stuck On Bank1
    P2653 B Rocker Arm Actuator Ctrl Circ Low Bank1
    P2654 B Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2655 A Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2656 A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2657 A Rocker Arm Actuator Sys Stuck On Bank2
    P2658 A Rocker Arm Actuator Ctrl Circ Low Bank2
    P2659 A Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2660 B Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2661 B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2662 B Rocker Arm Actuator Sys Stuck On Bank2
    P2663 B Rocker Arm Actuator Ctrl Circ Low Bank2
    P2664 B Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2665 Fuel Shutoff Valve B Ctrl Circ/Open
    P2666 Fuel Shutoff Valve B Ctrl Circ Low
    P2667 Fuel Shutoff Valve B Ctrl Circ Hi
    P2668 Fuel Mode Indicator Lamp Ctrl Circ
    P2669 Actuator Supply Voltage B Circ /Open
    P2670 Actuator Supply Voltage B Circ Low
    P2671 Actuator Supply Voltage B Circ Hi
  7. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2700 - P2799
    P2700 Trans Friction Element A Apply Time Range/Perf
    P2701 Trans Friction Element B Apply Time Range/Perf
    P2702 Trans Friction Element C Apply Time Range/Perf
    P2703 Trans Friction Element D Apply Time Range/Perf
    P2704 Trans Friction Element E Apply Time Range/Perf
    P2705 Trans Friction Element F Apply Time Range/Perf
    P2706 Shift Solenoid F
    P2707 Shift Solenoid F Perf or Stuck Off
    P2708 Shift Solenoid F Stuck On
    P2709 Shift Solenoid F Electrical
    P2710 Shift Solenoid F Interm
    P2711 Unexpected Mechanical Gear Disengagement
    P2712 Hydraulic Power Unit Leakage
    P2713 Press Ctrl Solenoid D
    P2714 Press Ctrl Solenoid D Perf or Stuck Off
    P2715 Press Ctrl Solenoid D Stuck On
    P2716 Press Ctrl Solenoid D Electrical
    P2717 Press Ctrl Solenoid D Interm
    P2718 Press Ctrl Solenoid D Ctrl Circ / Open
    P2719 Press Ctrl Solenoid D Ctrl Circ Range/Perf
    P2720 Press Ctrl Solenoid D Ctrl Circ Low
    P2721 Press Ctrl Solenoid D Ctrl Circ Hi
    P2722 Press Ctrl Solenoid E
    P2723 Press Ctrl Solenoid E Perf or Stuck Off
    P2724 Press Ctrl Solenoid E Stuck On
    P2725 Press Ctrl Solenoid E Electrical
    P2726 Press Ctrl Solenoid E Interm
    P2727 Press Ctrl Solenoid E Ctrl Circ / Open
    P2728 Press Ctrl Solenoid E Ctrl Circ Range/Perf
    P2729 Press Ctrl Solenoid E Ctrl Circ Low
    P2730 Press Ctrl Solenoid E Ctrl Circ Hi
    P2731 Press Ctrl Solenoid F
    P2732 Press Ctrl Solenoid F Perf or Stuck Off
    P2733 Press Ctrl Solenoid F Stuck On
    P2734 Press Ctrl Solenoid F Electrical
    P2735 Press Ctrl Solenoid F Interm
    P2736 Press Ctrl Solenoid F Ctrl Circ/Open
    P2737 Press Ctrl Solenoid F Ctrl Circ Range/Perf
    P2738 Press Ctrl Solenoid F Ctrl Circ Low
    P2739 Press Ctrl Solenoid F Ctrl Circ Hi
    P2740 Trans Fluid Temp Sens B Circ
    P2741 Trans Fluid Temp Sens B Circ Range Perf
    P2742 Trans Fluid Temp Sens B Circ Low
    P2743 Trans Fluid Temp Sens B Circ Hi
    P2744 Trans Fluid Temp Sens B Circ Interm
    P2745 Intermediate Shaft Speed Sens B Circ
    P2746 Intermediate Shaft Speed Sens B Circ Range/Perf
    P2747 Intermediate Shaft Speed Sens B Circ No Signal
    P2748 Intermediate Shaft Speed Sens B Circ Interm
    P2749 Intermediate Shaft Speed Sens C Circ
    P2750 Intermediate Shaft Speed Sens C Circ Range/Perf
    P2751 Intermediate Shaft Speed Sens C Circ No Signal
    P2752 Intermediate Shaft Speed Sens C Circ Interm
    P2753 Trans Fluid Cooler Ctrl Circ/Open
    P2754 Trans Fluid Cooler Ctrl Circ Low
    P2755 Trans Fluid Cooler Ctrl Circ Hi
    P2756 Torque Conv Clutch Press Ctrl Solenoid
    P2757 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
    P2758 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
    P2759 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
    P2760 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Interm
    P2761 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
    P2762 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
    P2763 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
    P2764 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
    P2765 Input/Turbine Speed Sens B Circ
    P2766 Input/Turbine Speed Sens B Circ Range/Perf
    P2767 Input/Turbine Speed Sens B Circ No Signal
    P2768 Input/Turbine Speed Sens B Circ Interm
    P2769 Torque Conv Clutch Circ Low
    P2770 Torque Conv Clutch Circ Hi
    P2771 Four Wheel Drive (4WD) Low Switch Circ
    P2772 Four Wheel Drive (4WD) Low Switch Circ Range/Perf
    P2773 Four Wheel Drive (4WD) Low Switch Circ Low
    P2774 Four Wheel Drive (4WD) Low Switch Circ Hi
    P2775 Upshift Switch Circ Range/Perf
    P2776 Upshift Switch Circ Low
    P2777 Upshift Switch Circ Hi
    P2778 Upshift Switch Circ Interm/Erratic
    P2779 Downshift Switch Circ Range/Perf
    P2780 Downshift Switch Circ Low
    P2781 Downshift Switch Circ Hi
    P2782 Downshift Switch Circ Interm/Erratic
    P2783 Torque Conv Temp Too Hi
    P2784 Input/Turbine Speed Sens A/B Correlation
    P2785 Clutch Actuator Temp Too Hi
    P2786 Gear Shift Actuator Temp Too Hi
    P2787 Clutch Temp Too Hi
    P2788 Auto Shift Manual Adaptive Learning at Limit
    P2789 Clutch Adaptive Learning at Limit
    P2790 Gate Select Direction Circ
    P2791 Gate Select Direction Circ Low
    P2792 Gate Select Direction Circ Hi
    P2793 Gear Shift Direction Circ
    P2794 Gear Shift Direction Circ Low
    P2795 Gear Shift Direction Circ Hi
  8. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P2A00 - P2A99
    P2A00 O2 Sens Circ Range/Perf Bank1 Sens1
    P2A01 O2 Sens Circ Range/Perf Bank1 Sens2
    P2A02 O2 Sens Circ Range/Perf Bank1 Sens3
    P2A03 O2 Sens Circ Range/Perf Bank2 Sens1
    P2A04 O2 Sens Circ Range/Perf Bank2 Sens2
    P2A05 O2 Sens Circ Range/Perf Bank2 Sens3
  9. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P3400 - P3499
    P3400 Cylinder Deactivation Sys Bank1
    P3401 Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
    P3402 Cylinder 1 Deactivation/Intake Valve Ctrl Perf
    P3403 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
    P3404 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
    P3405 Cylinder 1 Exhaust Valve Ctrl Circ/Open
    P3406 Cylinder 1 Exhaust Valve Ctrl Perf
    P3407 Cylinder 1 Exhaust Valve Ctrl Circ Low
    P3408 Cylinder 1 Exhaust Valve Ctrl Circ Hi
    P3409 Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
    P3410 Cylinder 2 Deactivation/Intake Valve Ctrl Perf
    P3411 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
    P3412 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
    P3413 Cylinder 2 Exhaust Valve Ctrl Circ/Open
    P3414 Cylinder 2 Exhaust Valve Ctrl Perf
    P3415 Cylinder 2 Exhaust Valve Ctrl Circ Low
    P3416 Cylinder 2 Exhaust Valve Ctrl Circ Hi
    P3417 Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
    P3418 Cylinder 3 Deactivation/Intake Valve Ctrl Perf
    P3419 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
    P3420 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
    P3421 Cylinder 3 Exhaust Valve Ctrl Circ/Open
    P3422 Cylinder 3 Exhaust Valve Ctrl Perf
    P3423 Cylinder 3 Exhaust Valve Ctrl Circ Low
    P3424 Cylinder 3 Exhaust Valve Ctrl Circ Hi
    P3425 Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
    P3426 Cylinder 4 Deactivation/Intake Valve Ctrl Perf
    P3427 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
    P3428 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
    P3429 Cylinder 4 Exhaust Valve Ctrl Circ/Open
    P3430 Cylinder 4 Exhaust Valve Ctrl Perf
    P3431 Cylinder 4 Exhaust Valve Ctrl Circ Low
    P3432 Cylinder 4 Exhaust Valve Ctrl Circ Hi
    P3433 Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
    P3434 Cylinder 5 Deactivation/Intake Valve Ctrl Perf
    P3435 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
    P3436 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
    P3437 Cylinder 5 Exhaust Valve Ctrl Circ/Open
    P3438 Cylinder 5 Exhaust Valve Ctrl Perf
    P3439 Cylinder 5 Exhaust Valve Ctrl Circ Low
    P3440 Cylinder 5 Exhaust Valve Ctrl Circ Hi
    P3441 Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
    P3442 Cylinder 6 Deactivation/Intake Valve Ctrl Perf
    P3443 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
    P3444 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
    P3445 Cylinder 6 Exhaust Valve Ctrl Circ/Open
    P3446 Cylinder 6 Exhaust Valve Ctrl Perf
    P3447 Cylinder 6 Exhaust Valve Ctrl Circ Low
    P3448 Cylinder 6 Exhaust Valve Ctrl Circ Hi
    P3449 Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
    P3450 Cylinder 7 Deactivation/Intake Valve Ctrl Perf
    P3451 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
    P3452 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
    P3453 Cylinder 7 Exhaust Valve Ctrl Circ/Open
    P3454 Cylinder 7 Exhaust Valve Ctrl Perf
    P3455 Cylinder 7 Exhaust Valve Ctrl Circ Low
    P3456 Cylinder 7 Exhaust Valve Ctrl Circ Hi
    P3457 Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
    P3458 Cylinder 8 Deactivation/Intake Valve Ctrl Perf
    P3459 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
    P3460 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
    P3461 Cylinder 8 Exhaust Valve Ctrl Circ/Open
    P3462 Cylinder 8 Exhaust Valve Ctrl Perf
    P3463 Cylinder 8 Exhaust Valve Ctrl Circ Low
    P3464 Cylinder 8 Exhaust Valve Ctrl Circ Hi
    P3465 Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
    P3466 Cylinder 9 Deactivation/Intake Valve Ctrl Perf
    P3467 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
    P3468 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
    P3469 Cylinder 9 Exhaust Valve Ctrl Circ/Open
    P3470 Cylinder 9 Exhaust Valve Ctrl Perf
    P3471 Cylinder 9 Exhaust Valve Ctrl Circ Low
    P3472 Cylinder 9 Exhaust Valve Ctrl Circ Hi
    P3473 Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
    P3474 Cylinder 10 Deactivation/Intake Valve Ctrl Perf
    P3475 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
    P3476 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
    P3477 Cylinder 10 Exhaust Valve Ctrl Circ/Open
    P3478 Cylinder 10 Exhaust Valve Ctrl Perf
    P3479 Cylinder 10 Exhaust Valve Ctrl Circ Low
    P3480 Cylinder 10 Exhaust Valve Ctrl Circ Hi
    P3481 Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
    P3482 Cylinder 11 Deactivation/Intake Valve Ctrl Perf
    P3483 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
    P3484 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
    P3485 Cylinder 11 Exhaust Valve Ctrl Circ/Open
    P3486 Cylinder 11 Exhaust Valve Ctrl Perf
    P3487 Cylinder 11 Exhaust Valve Ctrl Circ Low
    P3488 Cylinder 11 Exhaust Valve Ctrl Circ Hi
    P3489 Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
    P3490 Cylinder 12 Deactivation/Intake Valve Ctrl Perf
    P3491 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
    P3492 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
    P3493 Cylinder 12 Exhaust Valve Ctrl Circ/Open
    R.L.K. likes this.
Thread Status:
Share This Page
