Truck Randomly Died While Driving
Discussion in 'General Discussion' started by Jrock2394, Dec 15, 2016.
  1. Jrock2394
    Jrock2394 Senior Member
    168
    56
    Feb 8, 2014
    Ram Year:
    1996
    Engine:
    5.2 V8
    So after 4 years with no major problems in this truck, i was on my way home and out of nowhere i lost all power. It was like i turned the key completely off. Luckily i was near a parking lot and managed to pull in with no power steering.
    Here is the kick, the truck has been running perfect. I didnt even feel a hesitation at all before it quit. Also, it is not throwing any codes at all. Since it was colder than a witches tit, i only managed to check a few things. It has fuel pressure, and it turns over fine, and i unplugged the MAP sensor to see if i can get it into limp mode (no luck), and checked all the fuses. Everything looks fine it just will not start.
    I did put gas in it about 10 minutes prior which leads me to believe i could have gotten bad gas. But not sure if that would cause it to completely die without any signs.
    Any insight on this would be great. Tomorrow after work Im going to clean the IAC and see if i can see or find anything else out of the ordinary.
  2. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,856
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Iac won't cause it to die while driving as it's not in play. Ohm check the coil for 12-15k ohms between the tower and either pin. If that checks good you might want to look at replacing the crank sensor
  3. Max78
    Max78 Senior Member
    107
    11
    Jul 20, 2016
    AZ
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    Swap your ASD (auto shutdown relay) with you ac compressor relay. I had the same thing happen to me and swaping relays fixed it for me.
  4. Jrock2394
    168
    56
    Feb 8, 2014
    Ram Year:
    1996
    Engine:
    5.2 V8
    I'll take a look at that coil when I get home today. Thanks for the heads up on the IAC.
    If the ASD was bad wouldn't that cause the fuel pump to not start? I have pressure to the rail right now.
  5. dapepper9
    22
    4,779
    1,856
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Yes it would and starter wouldn't engage
  6. dudeman2009
    dudeman2009 Senior Member
    22
    1,398
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    That is correct, the IAC feeds the fuel pump as well.
  7. Meatball12
    Meatball12 Member
    78
    15
    Sep 23, 2015
    Carroll County, MD
    Ram Year:
    1999
    Engine:
    5.9 magnum
    sounds similar to what happened to me few months ago. Ended up being my fuel pump.
  8. Max78
    Max78 Senior Member
    107
    11
    Jul 20, 2016
    AZ
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    Well thanks for the info on the ASD relay, when my truck would die it would generally start right back up, only once did it give me a little trouble but that must have been unrelated. Swapping the ASD relay cleared everything up for me.
  9. Jrock2394
    168
    56
    Feb 8, 2014
    Ram Year:
    1996
    Engine:
    5.2 V8
    Just an update on this. Didn't get a chance to look at it yesterday because of snow so this morning I popped the hood to see what was going on. Upon further inspection, the ignition coil wire turned out to be laying on the manifold melted clean through. Popped the old wire off and put a new one on and it fired up. Guess I got lucky on this one thanks for the input guys appreciate it.
  10. scoose
    scoose Senior Member
    47
    311
    16
    Apr 14, 2011
    Atlanta
    Ram Year:
    2007 1500 sold, 2011 1500 5.7 sport sold, 2016 6.7 2500 4x4 sold, 2014 2500 5.7
    Engine:
    Do we have a prize for Dapepper??
Share This Page
