Truck will not heat up, has brand new heater core and I'm on my 4th thermostat. All started after replacing my plenum gasket. All parts from dodge. Made sure to burp the system and checked all fluids. Any ideas?
Year , engine please
Both. Last week I got a "too cold for too long" engine code and after that I put in my dodge thermostat, same result. The cab also has very very mild heat, would guess maybe 90 degrees blowing. The upper radiator hose I should replace, when I was changing thermostats it was pretty flexible..
Make sure you are installing a Mopar T stat and its being installed the correct way. The thermostat is the ONLY thing that can cause this issue
