gixxer
Hello,
I have a 2013 SLT with a 6.5 ft bed. I have the above mentioned tonneau cover. The truck was rear ended and they want to reuse the cover. However, on the tailgate side, the two back corners (corner plugs) with the weather seals (foam inserts) are not sitting on the bedrail to create a tight seal and are leaving a gap. I cannot remember if this is how it normally fits or if the tonneau cover got damaged in the accident and insurance is just trying to save some money and reuse it.
If anyone can tell me how their's is sitting and if you have pictures from directly behind the truck at the level of the tonneau cover that would be greatly appreciated. I have attached a link to the install instructions and I am referring to step 10.
https://www.truxedo.com/files/pdf/1116032-truxport-manual.pdf
Thanks.
Thanks.
