Trying to figure out what this part is!??
Discussion in 'Tech Info' started by Powerddge1138, Sep 2, 2014.
  1. Powerddge1138
    Powerddge1138 Junior Member
    16
    Jul 12, 2014
    Ram Year:
    1990
    Engine:
    360 5.9
    I took off my intake manifold cause the gasket was leaking coolant, so I thought while I had it off I'll send it to get power washed and sand blasted. Before they can sand blast it I had to remove everything off the intake well in trying to remove this part two of the nipples broke off and I can't find a new one anywhere! Please help me find one!
  2. crazzywolfie
    crazzywolfie Senior Member
    14,095
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    if you don't need all the vacuum ports you could just plug them. otherwise you will most likely have to find a used one.
  3. RonJon '06
    RonJon '06 Senior Member
    3,304
    1,047
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
  4. Powerddge1138
    16
    Jul 12, 2014
    Ram Year:
    1990
    Engine:
    360 5.9
    I found one in a junk yard! Now I'm trying to figure out what this plug goes Into? I've got it all back together accept this and it's bugging the crap out of me!
  5. crazzywolfie
    14,095
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    that might be for a/c if your truck would have had it.
  6. Powerddge1138
    16
    Jul 12, 2014
    Ram Year:
    1990
    Engine:
    360 5.9
    it doesnt have ac
  7. crazzywolfie
    14,095
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    but it still most likely has the plug for it. from the looks of the dirt on it it was not used anyway. if you really start looking around you will most likely find quite a few connectors that are just there for other packages that your truck may not have.
Share This Page
