Hey guys, I have a 1999 Ram 1500 and am replacing the headlights. I bought a pair off walmart.com (I now see the error of my ways). https://www.walmart.com/ip/153983309 is a link to the ones I got. I removed the old headlights and started wiring the new ones. I watched a couple videos on how the wiring works, but i still cant get them to work right. Here is what I have done so far:
-Connected the main headlight plug.
-Using quick connects, spliced into the power and ground wires to the park lights, and wired the LED's to them (White and Black wires on new headlight). The LED's come on with the park lights.
-Tried to connect what I assume are the Halo wires to the park lights as well (red and black - there are two of each that come out of the headlight housing, they go into a small box attached to the housing, and then one of each comes out). When I attempt to connect them though, I blow the park light fuse.
-I also tried to connect the aforementioned (red and black) wires to the main light power wires (the ones going to the headlights) and that also blows a fuse.
-The inner headlight in each assembly comes on (there are two lights in each assembly) but when I turn on high beams everything goes very dim. The highbeam indicator on the dash stays on at all times (didn't do that before, high and low both worked fine prior).
So to sum up, I can't get the Halo's to work, I can't get my high beams to work, and I am pretty much at a loss. Anyone know what the heck is going on?
Edit: with the system that I have I think my problem is that I didn't use a HID relay harness. From anyone with experience in this, is that something that I need to upgrade my headlights?
