Tune from 6 speed to 8 speed Transmission
Jerseymike
Hey Sean,
I have a 2013 Ram 1500 with the 6 speed trans and one of your great tunes. I would like to install a 8 speed trans from either a 2013 or 2014 Ram. I have found several available for around $1000 at salvage yards with a matching PCM for $250.
So, could you program either: my stock PCM, the PCM that matches the donor trans, or one of you new PCM's to run with the 8 speed trans and my truck?
Seems like it should be possible. And maybe a better option than trying to keep the 6 speed from dying every 2 years.
:superhack:
hemifever
Preferred Vendor
Apex, NC
if you completed a swap and matched up the necessary wiring/ecu/trans for it to function 100% then it can be tuned correctly. i can't reprogram the change to function correctly if it's not mechanically correct
Jerseymike
Jerseymike
Yeah. Sounds like an expensive can of worms. I just installed a transgo reprogramming kit on the valve body and the trans is shifting much better(faster). If this trans goes, I will have to find a builder to beef it up next time.
