Underarock13
- Nov 14, 2015
- 342
- 114
- Ram 2500 14
- 6.4 hemi
Anyone using a tuner yet? Notice any difference or anything like that. I keep thinking about the Ike gauntlet run. Makes me sad .
It's easier said than done, but I would forget about that Ike run test. All it says is that if you want to load your truck to full gross combined and climb straight up a wall with your foot to the floor- you won't be the fastest. Who even tows like that?Anyone using a tuner yet? Notice any difference or anything like that. I keep thinking about the Ike gauntlet run. Makes me sad .
Sent from my SM-G925W8 using Tapatalk
Why? It isn't like it hurts performance at all, it makes the truck sound a little funny sure but there is no actual negative to it. Either way it takes 1 button press to shut it off anyway.I'd like a tuner for my 15 2500 just to turn off the dang MDS
I have ran pretty much every tune for the intune available and now have the hemifever tunes. If I had to do it over I wouldn't bother. With the hemifever tunes it woke the truck up a little, it is better off the line but it is still a 7000 pound truck, it takes a big hp gain to really feel anything. I really wanted it to gain a little fuel mileage, I maybe gained half of a mpg. So to me there isn't a gain by going with a tuner on the HD gas trucks.
Take your pick, I've ran the towing tune, 87 tune 87 hemifever tune, and fuel economy tune on 87 octane, and the Diablo tune and 93 octane hemifever tune on 93 octane.What octane fuel do you run?
I could feel it slightly but not near enough to justify the 50 cents more per gallon in fuel costs. I actually just sent him the datalog for the 93 tune (he didn't want the 87 logged) and he said everything was good. The trans tuning making the shifts firmer is nice but weird at the same time. The firmer shifts I like, but it still seems like the torque management is there pulling the throttle back so it can shift. It is like driving in a manual trans vehicle with someone who doesn't know how to shift, like the person lets off the throttle, pushes the clutch in, shifts and then drops the clutch while giving it gas. Under full throttle it is good, but partial throttle it seems weird. All in all for the cost of a new tuner and custom tune it wouldn't be worth it to me to do it again. For a 1500 that weighs 1500 to 2000 pounds less it would be more than worth it, but not in the HD's.Could you feel a difference when you stepped up from 87 to 93 octane? Did you send Sean Datalogs with each tune?
Aw heck, you will be fine with that. Dry weight of 6400, so a full loaded weight of what, 8 or 8500? No worries. The Ike test was done with a 12500lbs trailer and ballast in the bed- I am betting 4000lbs or more than what you are looking at. Basically the test was performed with the truck at full GCWR. The Ike Gauntlet is designed to purposely push these trucks right to the very limit and then some- that's the intention. See how well they do when they are completely maxed out. That is a really miserable climb that many people won't make with that kind of weight behind a gasser. I really don't think you have anything to worry about. I have never pulled on a grade like the ike, but the Frenchman Valley here is a 7% grade over a number of miles, and the Sask Landing hills are similar in length and grade. In the Frenchman I didn't have any issues holding 90kmph (55mph?) all the way to the top, it wasn't pinned- it did fine with power to spare. The elevations here don't match those in the ike test though.
In short, don't worry about it unless you have to. I understand your reservations, I had them too before I bought because of that silly video. I am pretty sure that truck will handle it fine
I don't think that truck in the Ike Gauntlet was maxed out. It had a 22,500 lb GCWR and it was pulling 19,500 GCWR which is only 86% of it's max GCWR that Ram gave it. The GM 2500 HD 6.0L on the other hand closer to its max rating at 95% of it's GCWR when pulling the same 12,500 lb trailer.
It won all the other tow tests and it's tow rating capacity is set by SAE J2807 standards.
Did the programming hinder performance over the IKE? Yup. But here are some other questions...
What were the water temps of both vehicles?
Oil temps?
Transmission temps?
I'm sure the Ford and Chevy were screaming in first and bogging in second back and forth. The Chevy is in the video, making the test drivers comment about it gear hunting.
