Unknown Problems.
Discussion in 'Engine & Performance' started by bluwarguy, Dec 26, 2016.
Sponsored By: Moe's Performance
  1. bluwarguy
    bluwarguy Member
    67
    Oct 20, 2016
    Ram Year:
    1997
    Engine:
    5.9 Magnum V8
    Whenever I accelerate hard (like when I pass somebody on the highway) I've noticed that my check engine light starts to flash. The check engine light is also on and gives me 2 codes: 12 and 43. My oil consumption is awful and I have to constantly buy oil for my truck. Sometimes when starting it in the cold, it doesn't like to stay on and I have to slightly give it gas for about a minute and it'll stay on. If not then it sputters and dies. Are any of these problems related and what could the main problem be?
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,457
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Oil consumption followed by cylinder misfire (Generally what the flashing CEL means) on a dodge means its time for the plenum.
    Code 12 just means the battery has been disconnected within a certain number of ignition cycles.
    Code 43 could be a couple things but usually is random multiple cylinder misfire.
    I'd go with the plenum but you can also check your ignition coil.
    Measure the resistance of your coil from the tower to a pin on the input you should get about 12k-15kohms. Between the two input pins should read about 1-2ohms. If either is wildly off, replace the coil.
  3. bluwarguy
    bluwarguy Member
    67
    Oct 20, 2016
    Ram Year:
    1997
    Engine:
    5.9 Magnum V8
    so Code 43 could be fixed with the plenum kit?
  4. pajeepman
    pajeepman Senior Member
    128
    Aug 30, 2015
    SE PA
    Ram Year:
    2003
    Engine:
    5.9 magnum
    Oil loss without visible leak is almost certainly a plenum issue. I replaced mine with an aluminum one from ebay. No issues for 4 months so far.
    Sent from my SM-J320P using Tapatalk
  5. dapepper9
    dapepper9 Senior Member
    22
    4,834
    1,867
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Yes start with plenum and in the process of doing it do a tune up as well
  6. bluwarguy
    bluwarguy Member
    67
    Oct 20, 2016
    Ram Year:
    1997
    Engine:
    5.9 Magnum V8
    I bought an OBDII reader and found that the code is specifically P0308, so Cylinder 8 is the one misfiring.
  7. dudeman2009
    22
    1,457
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    Cylinders 7 and 8 are the most common ones to go with plenum issues.
  8. dapepper9
    22
    4,834
    1,867
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Cylinder 8? Plenum
  9. pajeepman
    128
    Aug 30, 2015
    SE PA
    Ram Year:
    2003
    Engine:
    5.9 magnum
    Plenum guaranteed. Same problem i had minus the not staying running.
  10. Truemagnum15
    Truemagnum15 Junior Member
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    We recently bought an aluminum plenum kit from Hughes engines and it included all gaskets, bolts, etc. needed for $142 total for shipping and the kit.
Share This Page
