Upper ball joint replacement
Discussion in 'Lifted' started by MarkV, Dec 5, 2016.
  1. MarkV
    MarkV Senior Member
    1,236
    482
    Nov 24, 2014
    Ontario, Canada
    Ram Year:
    2003
    Engine:
    4.7 Magnum V8 NOW with Moose Power
    How big of a deal it is to replace the upper control arm? I have to do my drivers side. Should i do both? And do i have to bring it to a shop to get it re aligned? Or can i mark it and that's close enough?
    Grey dodge likes this.
  2. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    Replace them both and be done with it. They just unbolt from the frame and you just get a ball joint separator (picklefork) and separate ball joint from knuckle. Are the really worn out and sloppy or just worn? If they're just worn then you should be good, but if they got a good bit of slop then I would recommend an alignment.
    MarkV likes this.
  3. MarkV
    MarkV Senior Member
    1,236
    482
    Nov 24, 2014
    Ontario, Canada
    Ram Year:
    2003
    Engine:
    I think worn. There is a bit of play. So just make sure the bolts are in the exact same place....? I have done all the other ball joints...
  4. SilverStreak88
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    If it's just a little play then you should be good. Just take the 2 bolts at the frame out and separate the ball joint, then reverse.
    MarkV likes this.
  5. destroyaYO
    destroyaYO Member
    30
    54
    25
    Nov 22, 2016
    Ram Year:
    Engine:
    5.7L V8 Hemi
    For sure alignment . Especially if your lifted . You may not feel but your tires will start to wear funny. That will put small amount of stress on everything. Over time it could turn into a big deal . I would check your outer tie rods during this process too.
    MarkV likes this.
  6. Marciel
    Marciel Senior Member
    33
    206
    59
    Feb 4, 2017
    Ram Year:
    2006
    Engine:
    It's cake, 90% of the time you don't need a separator just tap the bolt and it pops right out of the knuckle. I'd suggest upgrading to at least a movetec wile your there though.
    Sent from my SM-N910V using Tapatalk
Share This Page
